Question about Extended Systems ExtendNet 100D (ESI-2951B) Print Server
Lost the transformer
Esi-2811 What is the voltage off this print server?
Anything like 10to40volt
Posted on Jun 18, 2008
WHAT ARE TRANSFORMERS
Wall socket power (high voltage) is known as AC (Alternating Current). Battery power (low voltage) is known as DC (Direct Current). Transformers are electrical converters that change AC input to DC output or DC input to AC output. This is required to charge or to supply mains power for most portable devices that use batteries when not plugged in, or devices that do not have batteries but still require DC power input. Examples of such devices are laptops, phones, tablets, printers, print servers etc. A transformer for your print server is most likely a black box in line with the power cable. In this case you will need a new power cable which will include the transformer. Some transformers are within the device itself with a power socket in the back of the device. If this is the case then replacement of the transformer (or sometimes the whole device) is required depending on the price of parts, sometimes replacing the whole device is cheaper.
Jan 15, 2014 | Lexmark N5 (12J0020) Print Server
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
I need a AC Adapter Kit for the Extended Systems PocketPro Print Server ESI-7000RX
Some are proprietary and can only be obtained from the manufacturer or dealer. Go to their web site and look at the accessories available.
Mar 06, 2011 | Extended Systems PocketPro Print Server
I have an extendnet sx ESI-2811 Print Server. It doesn't work and I can't ping it when directly connected to my laptop via ethernet cable. It must be broken. Any ideas?
Use a crossover cable to connect laptop directly. Does your print server have a static IP address and do you know what it is? If yes, set a static IP on your laptop that is in the same subnet and with the same mask, then you should be able to ping it. If the print server is obtaining an IP by DHCP, you will have to set up and run a DHCP server on the laptop (or connect it with a straight-thru cable to an existing router that offers this service).
Jun 21, 2010 | Computers & Internet
Cable/Transformer for Quantum Server 1000
I've got the same Snap Server 1000 and lost the supply some time ago - I found a LiteOn monitor supply model PA-1400-02 does the trick and fits exactly.
Spec is 3.33A 12Volts DC out, positive inner, negative outer.
Hope that helps.
Jan 19, 2009 | Quantum Snap Server 1000 (5325301081) 10...
How to reset Pocket Print server Extended Sys ESI 2833?
Disconnect the power. Press the small test button and keep it pressed, while you reconnect the power AND wait until the green LED is on again.
Dec 05, 2008 | Extended Systems PocketPro Print Server
ExtendNet Pocket Printer ESI-2841 - Link Light fails to come on.
Did you connect it hrough a swirch with a network cable, or to a pc with a crossover? It is not a smart adapter, can't do midi or tx.
Oct 31, 2007 | Troy ExtendNet SX Print Server
ESI-2831 Drivers missing
Here is a Manual. As for the drivers came up short on them sry. www.nls.com/common/pdfs/v307n10.pdf
Apr 19, 2007 | Extended Systems Pocket Print Server
Can't find printserver on the network
Most Print Servers are by default on DHCP and if the PS is still on its factory defaults, it won't get an IP address because your computer won't have a DHCP server (unless u have set up one). Now, you can ask the person you got it from if he had ever assigned a static IP Address to the PS. Also, one of the reasons why your laptop won't detect the PS might be a software firewall installed. Please revert back with any other questions or observations. good luck
Mar 23, 2007 | Extended Systems Pocket Print Server
ESI-2833
User: admin Password: extendnet
Feb 21, 2007 | Extended Systems PocketPro Print Server
Extended Systems ExtendNet 100D (ESI-2951B) Print Server Logo
176 people viewed this question
Top Extended Systems Computers & Internet Experts
David Payne
David Payne
Are you an Extended Systems Computer and Internet Expert? Answer questions, earn points and help others
