How to deactivate quiet mode
You can simply change by changing the profile on your phone, if the phone is put on silent profile then it will be in a quite mode, go to the menu of the phone, then select settings, select phone settings, there you will see phone profile, then select Normal profile, this will deactivate the quite mode of the phone. Depending of the phone you are using, like my samsung d780, I simply hold down the # key to deactivate the silent mode, check your phone keypad as well to see if there is a key like that, but if there is no key like that simply follow the steps I put above. Thanks
