I have had this unit for over 1 year. Its a Philips DVDR3455/37. The past few weeks the dvd player has been buggy. As in it won't open when the button is pressed. Then yesterday it would not come up to the playing state. I have unplugged it and let it set for some time then plugged it back in. It gets to the name philips and stops. No response from the remote or the on off switch on the front of the unit. If I unplug it and plug it back in I get the time on the display. Then turn it on and it goes to the Philips display and stops. It seems like a firmware hang but not sure. I also hear a noise like the dvd wanting to move the tray but not sure. As it is out of warranty I could open it up but don't know what to look for. Thanks for your help on this matter.
-   I have the same problem and called the Phillips help desk. After trying several reboots they finally said to 'throw the unit in the trash' because nothing could be done to fix it.
I still have the unit and am hoping someone comes up with a fix because the Help Desk was of no 'Help'.-   GPOP
Jan 11, 2008
-   Hi there, I had the exact same problem. I've had the unit just over a year and watching a movie from my lap top on my TV through the DVDR3455 when my sound stopped. I've had this issue before and it is usually cause by the DVDR3455 locking up (like it seems to do every 3 to 4 times a month). So I go and unplug the unit and plug it back in and it never completely comes back up. I take a closer look at what it is doing and it seems to be coming part way up and then resetting itself. The sequence is I plug it in and get the time on the front, I use the remote or power button to power it on and the front displays "PHILIPS" and I can here it accessing the hard drive. But then after about 20-30 seconds the blue had drive light goes out and the unit reboots. The unit is unresponsive to the remove or power button when it gets into this mode. I thought maybe the hard drive got damaged, so I took it out and did a thorough test of the hard drive and there wasn't anything physically wrong with the hard drive. I tried poweing it up without the hard drive connected and it seems to do the same thing.
My best guess is that some diagnostic test is failing on boot up and the unit is restarting on this failure.
Any ideas from anyone whould be greatly appreciated. -   bmckinlay
I followed the instructions to make the "upgrade CD" and inserted into my DVR. My unit then powered up normally. I went ahead and upgraded the software and it did happen again (the re-boot cycle) until I entered the date/time.
I have HD writer AE when I try to burn a dvd from my panasonic movie cam I get the message Disc not...
(More)
I have HD writer AE when I try to burn a dvd from my panasonic movie cam I get the message Disc not supported what does this mean? and how can I burn a dvd from my digital camera if I can't use this program? untechnocrat
I bought a dvd from America and now find that it is the wrong area or zone code it is 1 for the USA...
(More)
I bought a dvd from America and now find that it is the wrong area or zone code it is 1 for the USA and 4 For NZ. How do I change my code from a 4 to all?.
Thankyou
For any discs i inserted to the player, it said the disc is not supported.... what can i do now......
(More)
For any discs i inserted to the player, it said the disc is not supported.... what can i do now... and sometimes the dvd tray cannot be opened and closed. i can hear some stange sound everytime the tray is malfunctioned.
Thanks for help~
p.s. my model is DVDR3455H/97
will not load dvds will say no disk . will play cds music sound is good fm radioeverything works no...
(More)
will not load dvds will say no disk . will play cds music sound is good fm radioeverything works no movies
