Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTPS rinse only light is blinking
Rinse light is blinking. all other buttons non-responsive...... washer worked yesterday..
  • 1 more comment
  • antz123 Jan 03, 2008
    I pressed keys one at a time then hit cancel...but it did not work
  • Anonymous Mar 28, 2014
    Normal light on solid and heated light on solid will not start
    Normal light flashing
  • 1,314 Answers
Mutiple keys stuck press keys one at a time then hit cancel
Posted on Dec 30, 2007
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Moffat washer light blinking and stops at either full load or stops at rinse cycle
I have the exact same problem on my clothes, washer. Lights blinking, then it stops at the end of the rinse cycle. What the ****. Moffat blows
Dec 20, 2010 | Washing Machines
Clean light is blinking and cannot use dishwasher
Thanks for using FixYa. If the green/clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 03, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
Starts but will not go into wash cycle
My solution to this problem was to simply unplug the power from the wall for a few seconds...plug back in, try to cycle again and the wash cycle starts fine now. May have been caught in a cycle loop or something. Any way this solution worked for me hope it works for someone else.
May 23, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
Have a whirlpool dish washer it wont work the cancel drain button is blinking how do i reset that thanks
have you tried refilling salt and rinse aid?
if that do'nt work it probably needs servicing it could be drain pipe blockage.
Jun 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
430 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
