Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help it wont stop changing channel by its self?
My tv wont stop changing channel by itself no matter what i'm watching can anyone help?
  • 1 more comment
  • andypop1 Jan 01, 2008
    i have samsung le37s86bd lcd while watching one channel it will switch to dtv channel by itself sometimes it will switch back automatically but usally i havet to use the remote to go back to original channel
  • Anonymous Mar 15, 2014
    I moved my tv and plugged it in the channel changer button stopped working when I press it it acts like the channel is being changed but it just stays on the same one???? I can change channels by entering the channel number but can't scroll through channels. What can I do to fix this?
  • Anonymous Mar 24, 2014
    it won't do a channel scan!!!
  • 124 Answers
Sluger,
Check for a stuck remote button. Take the batteries out of remotes and see if that stops it. If you have Dish Network, let me know.
Posted on Apr 08, 2008
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Dec 14, 2015 | Televison & Video
My emerson ls320em1 has good pic bt the volume goes up n down by it self
Does this happen while watching a program or just when changing channels? Most cable companies are notorious for not balancing their sound levels form channel to channel. Same applies to off air programs too Make sure the connecting cables have a good connection and are of high quality. Anything else is in the tv itself.
Jan 03, 2014 | Televison & Video
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
Dec 06, 2010 | HP PL5060N 50 in. Plasma HDTV
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Channels change by themselves after 20-30 minutes of tv being on
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Jun 06, 2008 | Insignia 42" LCD Flat-Panel HDTV
Catching one Channel Only
A TV card probably wont be able to tune it in...or decode(decrypt) it for that matter. Is a CableTv set top box plugged in? (the box your cable company supplies you with) -damian
May 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
My tv changes channel by it self
I have the same problem, anyone with a solution
Oct 25, 2007 | RCA P52926 52" Rear Projection Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
505 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
