Question about Sharp 27C-240 27" TV
Tv shuts off
Programming remote then all the channel volume menu and on off buttons wouldnt work and channels were moving so i couldnt get tv to shut off i unplugged it and now it wont come back on
  • 106 Answers
You a probablyt enter in service mode for that tv set ,contact a service man
Posted on Feb 04, 2008
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
I have a sony trinitron about 27 to 32 inches. it was left in the house when i moved in so there is no manual and no remote. I bought a universal remote that works but the tv is programed to certain...
Hi, if you have the remote control you go in the menu and you browse to set up and you choose air/ cable
and you set it to air or cable thene you press enter then you look for channel programing and press enter
and you will be don if dont have a remote you have a
menu button on the tv set push on and you browse
with channel up or down and select the option you want with volume + as i describe in the text.
hope that will help
have a nice day
Mar 28, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Nov 05, 2007 | Sharp 27K-S300 27" TV
My TV Says Line and Displays Just One Channel
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
Jul 12, 2006 | Panasonic PV-M2048 20 in. Combo
Sharp 27C-240 27" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
