Connections I have proficient M4 unit with 4 controlers PMKIR , I dont have the connection for Cat5 , and there is any way to download a manual for this unit, Thanks for you support Henry
    Sergeant:
    Champion:
  • 298 Answers
Proficient Contact Info
940 columbia avenue • riverside, california 92507 • 877.888.9004 • Fax 951.787.8747 • proficientaudio.com
Posted on Dec 30, 2007
  • Eugene Merritt Dec 30, 2007
    System ls controlled by infrared
    has six infrared flashers,or were
    you referring to something else
    • Four zones (four-room capability)
    • Hook up six component sources
    • 30 watts per channel per zone
    • All digital power amplification for high efficiency
    and cool operation
    • Includes four PMKIR single-gang master
    keypads with configurable buttons and
    integrated infrared receiver
    • Keypads feature one-button macro capability
    • Comes with six IR Single Flashers for source
    component control
    • Whole-house control for Party mode
    • Doorbell and Telephone paging mute
    • Proficient Editor software available for expanded
    feature programming
    • Optional numeric and function keypads
    • Optional Command Interface for IR capture and
    IR code testing
    Llnks to Proficient Editor Software Information:
    http://w6.adi-dist.com/_shared/_download...
    Link that explains how infrared is setup
    you should have rca connectors
    http://www.homeauto.com/Downloads/Produc...
    President:
  • 1,944 Answers
Here are some proficient manuals but you need to sign up (it's free). Here is the datasheet from proficient. I will look into this some more...
  • 691 Answers
Try sending Profocient an email and ask them to forward a manual to you:
www.proficientaudio.com
When trying to print more than 10 copies at a time, error code c-2558 appears and it stop printing..means it can only print 9 or 10 copies at a time but not more than that then error code appears
Code C2558 Description Abnormally high toner density detected TCR sensor
• TC ratio in the developing unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively. Remedy 1 Make sure that the following counter is cleared at the developer replacing. [Service Mode] - [Counter] - [Life] - [Developer Use Time] 2 Perform image troubleshooting procedure if image density is low. 3 Reinstall developing unit. 4 Reinstall toner bottle. 5 Check the contact of developing unit for proper connection and correct as necessary. 6 Check the connector between TCRSB CN29-relay CN28-PRCB CN24 for proper connection and correct as necessary. 7 Check the connector between M3-PRCB CN8 for proper connection and correct as necessary. 8 Check the connector between M4-relay CN13-PRCB CN8 for proper connection and correct as necessary. 9 M3 operation check. 10 M4 operation check. 11 Change developing unit. 12 Change TCRSB. 13 Change PRCB.
Feb 10, 2016 | Konica Minolta "Minolta Bizhub 363 Copier,...
Data imaging solution on c7000pro bizhub
7A00 Description Failed to arrive home
• Error of the imaging carriage home sensor. • Error of the carriage motor. Causes • Controller board (CTLB) • Imaging carriage home sensor (PS15) • Flatbed motor (M4) Remedy 1 Turn OFF/ON the main power switch. 2 Check CTLB for proper connection and correct as necessary. 3 Check PS15 and M4 for proper connection and correct as necessary. 4 Replace Flatbed unit. 5 Replace ADF unit. 6 Replace CTLB.
Dec 10, 2014 | Konica Minolta bizhub Office Equipment &...
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Kenmore elite he3t
maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
I've installed my wireless router, modelwrt54g2v1, and the yellow ethernet cable is still connected to my laptop, once I remove it I have no connection?
The yellow cable (CAT5) is giving you your internet connection
you will need to follow some steps:
1) Access the routers GUI (usualy by going to a web-page in your Internet explorer EG 192.168.0.1 check the manual)
2) make sure that wireless is enabled on the router + DHCP is enabled
3) at this stage set wireless security here as well (to stop unwanted use of your broadband and people hacking your PC)
4) make sure that the laptop wireless is switched on, sometimes there is both a physical on/off switch and a software/keyboard enable/disable button, disconnect the Yellow network cable
5) go to control panel:network connections
6) right click on the wireless connections icon and then view available wireless networks
7) if you see your network then highlight it and click connect
8) enter the security password (if any) which you set in step3 above.
let me know how you get on
Aug 29, 2008 | Computers & Internet
Wiring a P4M80-M4 mother board
You can download the manual for the motherboard here, just click on the "manual" link:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
This will list the front panel connections, which are 2 pins. Each of the jumpers, what you are calling clips, will connect two of the pins. Most cases have the jumpers labeled, i.e. power, reset, etc. But if they are not, it is usually: red/white = HDD led; green/white = power led; red/black = speaker; black/green = power switch; and black/white = reset. But your case may use a different wiring spec, but should list somewhere which wire is for which function.
Feb 28, 2008 | Computers & Internet
Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Dec 19, 2007 | Office Equipment & Supplies
146 people viewed this question
 Grubhead
Grubhead
