Question about Sony FD Trinitron WEGA KV-36HS20 36" TV
Need to center the picture
I need to center the picture on the screen. The picture has moved up on the screen. The bottom of the picture is cut off and in the HD mode there is a line on the top with the bottom of the picture above the line. Is there some adjustment that can be done to center the picture?
  • Sony Master
  • 1,689 Answers
This is a defect in the vertical scan amplifier. It is not an adjustment. Most of the time there are a number of capacitors in the vertical deflection amplifier that can cause this type of fault. Sometimes the output drive IC can cause this fault, but more rarely.
An experienced service tech can locate the defective parts and replace them. The average time involved is about 1 to 1.5 hours.
Jerry G.
Posted on Jun 02, 2008
Picture no longer centered in VGA mode
Is there any magentic material in and around that area?
Jul 18, 2012 | Televison & Video
Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
Hii, my L6 KM555R lost its Short cut bar at the bottom on the main menu, anyone know how to help, please and Thankss :)
Most times, it's just hidden! :) Move your mouse to the bottom center of the screen- (or to the right center, or left center) and see if it pops up... if it does, control click on the separator bar thing near the trash can, and click "turn autohide off." That should fix it!
Feb 13, 2011 | Computers & Internet
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it may be the inverter has gone bad. Inverters are like light bulbs and have life expectancies on the capacitors.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
To get to the inverter:
Remove the stand.
Take the screws out of the bottom rear edge (these hold the front trim)
The the trim then unsnaps. {Be aware of the wire to the power button board on the bottom corner}
Start at the bottom and release the trim by lifting away from the glass of the screen from the center outwards to the corners, then work your way up each side bottom to top (a pocket knife or thin putty knife will help release the catches) These sides can be really tough to pop off especially the last top clip on each side.
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the power button plug or unsrew the screws.
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift up.
unplug the bulbs and wire to the screen (screen plug that goes into the metal case pulls out)
then the inverter is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the inverter , I may be able to get a better idea if it is the inverter from a visual.
Dec 13, 2008 | Gateway FPD1975W 19" LCD Monitor
JVC av-56pw30 Picture Adjustment
Sounds like you have a convergence problem and the set will require repair. This repair will run somewhere around $400 if you have a good company complete the repair for you.
If you are interested in doing this repair yourself you will need to be able to use a meter and solder VERY well.
If you have more questions please email me.
Thank you,
Tim Nolan
Oct 11, 2008 | Televison & Video
Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Sep 22, 2007 | LG RU-44SZ51D 44" Rear Projection...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
Sony FD Trinitron WEGA KV-36HS20 36" TV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
