Question about Audiovox VM9512 Car DVD Player
E brake emlinate, putting in a offroad vehical that doesnt have one
Can i eliminate the e brake , and how putting in a off road machine that doesnt have e brake
  • oneiwdr Dec 31, 2007
    with remote
    press setup button
    scroll to highlight language
    enter 5,4,3,2,1,0
    you will now be in secrete menu
    turn brake pass on
    exit
    done
    Problem Solver:
  • 6 Answers
With remote
press setup button
enter 5,4,3,2,1,0
turn brake pass on
exit
done
Posted on Jan 02, 2008
Can i just hook the brake line to bypass the ABS system
try bleeding the abs lines on the abs booster under the hood it has an electric motor attached to it and is hooked directly from thebrake master cylinder it adds extra boost pressure to the brakes so you wont have to pump up the brakes when making a hard stop when traveling at a high rate of speed. try driving in an empty lot or road about 30 to 35mph then stepping on the brake real hard like if u were making an emergency stop you should hear the boost motor rev up and the wheels will stop an roll on and off several times until completly stopped then you will know its working but do not ever bypass that function unless the vehical is being built strictly for offroad uses only.
Nov 18, 2014 | GMC 98-04 Jimmy Sonoma Chevy S-10 Blazer...
Tip
Offroad driving
when driving offroad it is better to get some air out of the tires to get better grip and smoother ride
in deepsand it is recommended to get it as low as 10 psi on each tire
do not forget to fill it up right when you get back on the road!
have fun and drive safe
on Dec 02, 2009 | 1996 Land Rover Discovery
Jurking in the wheel motor completly shut down and all ligts on dash came on when restarted ligts go out and very hard to steer.
Could be alot of things and sounds very serious and dangerous...Need to have mechanic look at it....I would not fill comfortable giving suggestion as to what it could be....PLEASE have mechanic look at it.....good luck and hope info helps...
Aug 16, 2012 | 1997 Chevrolet Cavalier
I just had new brakes put on the front of my suzuki , rotors and pads on the front,but my my mechanic said the back brakes are drum brakes,he cleaned and lubricated them, but now the back brakes are...
I would take your vehical to another mechanic, preferably one who knows what they are talking about. If you vehical is still behaving strangly, you may have been ripped off.
Apr 17, 2011 | 2002 Suzuki XL-7
We have a 2001 Mazda Tribute and the yellow warning light on the dashboard is permanently on. Our mechanic is baffled. Can you help?
This vehical is notorious for problems, regardless of year 2000-2009, Same vehical as ford escape, mercury, You can disconnect the battery for 30 mins to reset indicator or You can go to most auto parts stores and have them put it on a check engine scanner for free and they can tell you what to replace plus they can clear the codes., but chances are with this vehical its going to be tranny related and big problems down the road. My friend just bought one 3 months ago with 70,000 miles and the tranny just burnt up o/d and reverse. $2000 fix. We had done a ton of research on this vehical and only found more problems. We were gonna do it ourselves but aamco had a sweet deal with warranty. Sell.Sell.Sell.
Oct 25, 2010 | Mazda Tribute Cars & Trucks
Installation with off road lights baja champion bc-600
HI,,
ITS PROBLEM WITH URS OFFROAD BULBS,,,
CHECK LOOSE CONNECTION AND BULBS...
TNKS
RABBANEES
Nov 11, 2009 | 2001 Ford F150 Styleside SuperCrew
I just replaced my offroad tires on my bike with road tires. Now I have a small, but noticeable, vibration in the pedals when I ride. Is this a derailleur issue?
It could be a d-rail, but also could be spokes, chain rub, wheel hitting a brake pad, tire clearance at frame, bearings.
Put your bike upside down so you can turn the pedals while you check for where this may be coming from.
Take your time... these noises can "telegraph' thru the frame and fool you so look for visible signs, use a little chain lube, oil , etc and you'll be able to pin point your noise.
I had an issue on my high end road bike.. a clicking while pedaling uphill...very annoying... turned out to be the added pressure caused the rear wheel spokes to click at the crossover point... a little heat shrink tubing did a nice alteration without a spoke pressure increase... So look around , start eliminating the possiblitites and you'll find it!
Sep 02, 2009 | Mountain Bike Bicycle Derailleur Hanger...
Doesnt want to come out of park. Turn the key on
I think I help you here. Sounds like a bad brake switch. This is what tells the computer you have accuated the brake pedal to take the vehical out of park. Chances are your brake lights are not coming on as well. Check this switch out, it's located under the dash on the driver's side, behind the brake pedal. Hope this helps, good luck!
May 11, 2009 | 2002 Saturn L-Series
To low
I did some searching and didn't come across much in the way of lift kits for your car. I found air-ride suspension setups which will allow you to raise it somewhat, but those aren't really meant for rock-crawling. To be honest though, your vehicle isn't really meant for it either (very few are - notable vehicles that are honestly meant for that stuff are the Jeep Wranglers and various Land/Range Rovers). The manufacturers make all kinds of claims about off-road abilities, but since the vast majority of owners never go farther offroad than their driveways, there really isn't much emphasis put into the design of SUVs anymore for offroading.
I did find one site that had a ton of items for your vehicle, and you can check it out here (this is their subpage meant directly for your car):
http://www.slickcar.com/accessories/santafe_accessories.asp
You could page through and see what they have, and you can always call them and see if they can sell you offroading gear, or refer you to someone who does. I doubt you'd be the first person that has asked them and I'm sure someone makes the gear for your truck.
Oct 26, 2008 | 2003 Hyundai Santa Fe
Audiovox VM9512 Car DVD Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
