HP
LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX
Confirmation Report
Description
By default, a Fax Confirmation report (Fax Call Report) will only print
when a fax error occurs. However, this option can be changed using the
printer control panel.
Press the right arrow until Reports appears in the display, press the checkmark.
Press the right arrow until Fax Call Report appears in the display, press the checkmark.
Press the right arrow until Print Report appears in the display, press the checkmark.
Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
Send Fax Only - a confirmation sheet will only print when a fax is sent
Never - no fax confirmation sheets
Every Error - default setting
Send Error - a fax confirmation prints when the fax transmission encounters an error
Every Fax - a fax confirmation sheet will print for incoming
I hope your fax is on a "surge Protector" providing protection for both Hydro and telephone line.
Use your operators manual to check setting of Confirmation Report as it can be set to OFF/ON. Proceedure varys by Manufacturer and model.
after emailing canon support, the answer is this:
1) the fax paper size must be "letter" - 8.5-11".
2) reset all settings through settings menu.
the fax will then print reports (and also every report that was not printed before).
1. Press Setup on the front panel of the All-in-One. 2. Press 5 or scroll down or use arrows to enter in to Print Report. 3. Press 4 or scroll down or use arrows to enter in to Fax Confirmation. Now scroll down or use arrows to find print after send fax and click on.
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
document.tlSearch.tx.value=unescape("")
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report
Description
Description
What do you want to reset?
