HP Photosmart M425 Digital Camera
Problem for HP Photosmart M425 Digital Camera
Message on camera:Lens Error:M425-12 (7f80)
By karenblevens on Oct 22, 2009
Message on camera:Lens Error:M425-12 (7f80) Lens won't
shut.
Solution #1
posted on Oct 22, 2009
Not Rated)
voodoomox
Rank: Wiz  HP Expert
Rating: 83%, 402 votes
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00646266&dlc=en&product=1147733
if the blue light flashes 4 times Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Was this helpful?
Yes
No
Solution #2
Not Rated)
wwwFCTRnet
Rank: Guide
Rating: 0%, 0 votes
This happens when the mechanism gets dirty. It requires a professional disassembly and cleaning.
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart M425 Digital
Questions and Unsolved Problems for HP Photosmart M425 Digital
Do you recommend HP Photosmart M425 Digital Camera?
Answer
Answer
When I turn the camera on everything is normal except I have a black display. The display works when... (More)
Answer
where can i get a replacement power button? the rocker broke and i need to replace the whole piece.
Answer
displays lens error when turned on will not take pictures, lens wont open
Answer
Went to use and took 1 shot then the batteries died. Changed then gave me error "batteries... (More)
Answer
the lens will not retract and the camera will shut off when trying to take a picture. the screen... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart M425 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
