RCAtv model 20V500T
I pushed the menu button on the tv, then pushed the FDA button, (Not knowing what that was)and the tv went off and can not be turned back on. I have no manual and I don't have the remote control for the tv. Can you help me?
  • will23810 Apr 27, 2008
    I pushed the menu button on the tv, then pushed the FDA button, and the tv is luck how do i take off the fda button
  • 373 Answers
Have you tried unplugging it for a while?
Posted on Dec 30, 2007
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
I still cannot turn off the fdp lock on my rca 20v500t
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Try this link for more details.
Sep 26, 2012 | RCA 20V500T 20" TV
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
I nedd to unlock my fpa on my RCA flat screen model 20V500T
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 26, 2012 | RCA Televison & Video
FDA lock off on RCA remote. TV won't turn on, does nothing
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 20, 2011 | RCA 20V500T 20" TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
I have an RCA model 20V500T television. There is an arcing noise coming from inside the back of the television. When this noise occurs a couple lines appear and disappear on the television screen. What...
High Voltage leak coming from anode button ,it nees to be resealed. TV contains around 20,000 volts up to 22,000 volts . Tube must be discharged in oder to correct problem .
Dec 27, 2010 | RCA 20V500T 20" TV
RCA 20V500T television. Inadvertently set FPA (parental control) to on. I shut TV off thinking it would reset. It is now in standby (in accordance with manual). It can only be turned on with remote. ...
Hello
You just try the following to open your TVs lock.
You must have its remote to unlock it.
OK.
Dec 23, 2010 | RCA 20V500T 20" TV
FDA Lock is on RCA Model 20V500T
Try unpluging for five ninutes the after plugging back in press and hold power button for 10 seconds...this should reset it!
Dec 18, 2008 | RCA 20V500T 20" TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
