Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
HD52w140 Wont turn on.
We have the same problem a lot of people are having in that the Resistor burned out. We realize that we probably have to replace the HV Block, however we have no idea what it looks like or where it is in this tv. If anyone can tell me where it would be that would be a huge help. Thanks
  • 1 more comment
  • JayCancel Jan 02, 2008
    have the same problem...need help in locating the part that needs replacing..thanx a bunch
  • IceHot Jan 02, 2008
    Actually, we figured out that the problem was just a burned our resistor (R14075) and a blown HV block. The HV block was 10 dollars and the resistor was only 30 cents. We have already installed them and the TV works like its brand new.
    Sorry you have had so many problems with yours.
  • rosie05 Jan 03, 2008
    ours is doing the same thing. We have found that if you sit in the floor and keep pressing the channel up and power botton repeatedly eventually it will make a popping sound and comes on. However, this process is becoming longer and longer. Did anyone experience this? At one point a tech said something about a processor needing replaced eventually. Is this the same thing?
  • 1,314 Answers
If that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rcaHD52w140 Wont turn on. - 2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Posted on Jan 02, 2008
My 2001 grand marquis heater turns on but wont blow i smelled a strange smell before it quit
Could have been the resistor or the blower motor. It was probably a burning wire smell.
Check the blower motor for power and ground.
Jan 22, 2014 | 2001 Mercury Grand Marquis
My stereo smells like it is burning and wont play cd's
The stereo probably has a burned resistor or one that is burning out. I would just replace it.
May 12, 2011 | Audio Players & Recorders
The heater shut off and won't turn back on. I checked the fuses and they are good and I checked the blower fan and it works too so I'm out of ideas on what to check.
check for voltage at blower motor plug, if no power possible blower motor resistor, a lot of times when resistor burnes out only high speed works and others burn out only one speed.
Jan 02, 2011 | 1997 Jeep Grand Cherokee
The air conditioning works, but only when the switch is turned to high. We tried replacing the switch, which did not work.
Good that you replaced the switch, but usually the resistor is also bad when this happens. The resistor is usually somewhere under the dash screwed into the duct with 2 screws and has a connector coming out of it with several wires. Remove the connector and unscrew the resistor. It will probably look burned up. If so, replace it.
If not, the wires have probably burned up somewhere along the way. If you have trouble finding the resistor, please let me know and i will try to locate it for you. It looks like this:3067b47.jpg
Sep 26, 2010 | 1995 Nissan Altima
The heater fan either makes noise, or today it only worked on high and had a smell to it, do i need to replace it?
This is definitely (based on works on Hi only) the Blower Motor Resistor located near the Blower Motor. It is defined with 3-4 wires going into it. It is easy to remove and replace. Purchase the part at the auto parts store versus at the dealer to save you a lot of money.
Install this first before deciding to replace the Motor.
After reinstalling, if the motor is making noise, turn it off IMMEDIATELY so you don't burn the resistor up again. The smell should be either the Resistor burning-up or the Motor burning out. The smell should have an odor like electrical burning?
Let me know if this helped, or if you have additional informatin or questions. Feel free to contact me on!
Let me
Jan 08, 2010 | 2005 Chrysler 300
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
Panasonic PT47WX53G Wont turn on or off (light continues blinking) R517 Burned out.
R517 is the auto brightness sense resistor, usually 10K. It fails when the LOPTX fails or the tube flashes over.
Jun 11, 2017 | Panasonic PT-47WX53 47" Rear Projection...
Tv problem dead set
Your flyback has shorted out and thats whats burning the resistors cahances are the HOT is shorted as well. You can get some information at the following link for RCA problems. Just leave them an email with your model and what the problem is
May 20, 2008 | RCA HD52W140 52" Rear Projection...
Rca scenium hd52w140 wont power up.... again
Sounds as if you'll have to replace the regulator and filter cap for it, at the very least. You may have taken out the flyback again, as they're not very hardy when driven with too much AC bias. The arc that you are calling a spark will have to be addressed also. If you have an intermittent connection at that point, the feedback voltage will be incorrect and you'll have the same scenario on dealing with a dead set once again. Hope this helps....accordianman
Feb 19, 2008 | Televison & Video
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
