Question about Pioneer SD-643HD5 64" Rear Projection Television
My tv is not as bright as it should be
Having trouble with my pioneer its not bright going to try to clean mirror and color bulbs what do i use window cleaner
  • Pioneer Master
  • 8,617 Answers
No don't use window cleaner it will cause bad streaking. Just use water with a damp soft cloth and dy with soft cloth.
Posted on Feb 04, 2008
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
I have a Pioneer SD-532HD5 Projection TV in which the picture is clear but dark and the colors appear weak- better color if a cartoon video. I have adjusted the contrast to max with minimal benefit and...
not convergence issue from description and if lens did not help when cleaned have a close look at the mirror as well to make sure not grimy or dirty, usually can peek in from the rear and up to examine it.
From the age of the set it could also be the tubes getting old but that would be unusual as have seen this set before and the tubes do not usually fail---problem if in the video circuit presents some challenges as a lot of parts for this set are no longer available.
take a look at the mirror with a bright light to see if smudged or grimy---looking straight at it may not show the dirt.
Jun 01, 2012 | Pioneer Televison & Video
I have an older Pioneer rear projection TV that has never been cleaned, model SD-P50A5-K. Can you give me the basic cleaning instructions and the do nots for this TV.
Unplug the TV for safety - even unplugged, there is enough energy stored in the electronics to be very dangerous.
The bottom speaker grill snaps straight off. There are a row of screws under the screen around the screen bezel that must be removed. The bottom of the screen will become loose and the whole screen assembly slides up, like opening a window (there is a bracket under the bezel at the top of the screen that the bezel slides off of.) My screen took a lot of effort to disengage the top bracket - careful not to break anything!!!
Once the screen is off, put it safely aside. There is a mirror in the back that can be cleaned with a damp cloth (not dripping wet!). Remove a little dust at a time and keep washing the cloth out between cleanings. Be very gentle. If you push on the mirror it could break If its never been cleaned there is sure to be a lot of crud.
Below the mirror are three colored lenses. CAREFULLY use a clean lightly damp cloth to wipe each one. Don't mess with any of the adjustment screws and levers on the lenses.
Before putting the screen back on the TV, carefully clean it with a damp cloth too. Slide the screen back over the top bracket, put the screws back in, and pop the speaker grill back on.
Its a good idea to readjust you convergence too.
When I cleaned my set, I was amazed at how bright and sharp the picture was!
Be Careful!
Jan 07, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
THE PICTURE IS TOO DARK. It is not as bright as it used to be.
Normally when your picture starts to get darker or dimmer it usually means that the lamp is almost out, your are able to go to a page called discount-merchant.com they have good prices on tv lamps and tv parts also and they also help you with questions you may have.
Dec 29, 2009 | Samsung DLP HL-P5663W 56" TV
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Hitachi projection tv.7years old.can i clean or change the bulb,w
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Feb 09, 2009 | Televison & Video
Thomson 50DSZ645
There is only one brightness bulb for your tv. You have the main bulbs which run the color for the Tv and then you have another bulb which runs the brighness. Typically it is a flourecent bulb inside which does need replacement now and then. Check tje specks on the tv's web site and you should be able to get the model number of the bulb from them and you should be able to purchase it from a repair shop or from online
Oct 23, 2008 | Thomson 50DSZ644 50" DLP Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
151 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
