Question about Gigabyte GA-8I845GVM-RZ Motherboard
Audio - does nowrking / forgot pin settings
Hi ,
My mother borad gone to repaire and after that my audio sound is not working, I checked that the audio pins/ are not connected , i am not able to put it back as i don't know the settings, please help.
  • Anonymous Aug 30, 2008
    My Motherboard driver do not match
    President:
  • 2,351 Answers
Your sound for this board is intergrated or known as part of the motherboard. It must be enabled in the BIOS. To get to your bios. During power up on the PC press the F1 key or Delete key ever couple of seconds. Some PC's require you to press other keys to get into the bios like F10 or F2 Use your manual to help guide you through the bios.
If you have a standard set of external speakers, one wire end colored Green, plugs into the back of your PC into the green hole for sound output. The pink colored hole is for a mic. If your bios is set to enable & you still have no sound output reinstall your sound drivers. Your sound drivers can be found on the link below:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1930
Posted on Dec 31, 2007
Key borad stating working after 3 min not work what is probalam mother board or SMPS
i think its the prbolem in your motherboard......
Or
Check your bios setting too
Or
Check your keyboard first
Aug 13, 2011 | Intel D102GGC2 Motherboard
I have Gigabyte Mother board GA-VM900M mother borad I not able to install audio driver, and also let me know which audio driver is recomennded
on this page
http://www.gigabyte.com/products/product-page.aspx?pid=2581&dl=1#dl
select your operating system and go
Feb 23, 2011 | Gigabyte GA-VM900M Motherboard
No audio
hi there,
If you don't have a audio driver, check your audio harware which brand is it?
First of all check which mother board are you using, if the mother board is builtin then you can find on the internet your driver by your motherboard name. like "Asus P5KPL_AM SE" sound driver.
secondly, if its not builtin then find out your sound card brand, which is mention on the sound card.
Thanx
May 15, 2010 | Computers & Internet
I have no audio driver
dear check the mother board, find the brand of the borad like intel or asus and check that wheather the Boar have inbuilt audio device , if yes you have to download the driver and install it, def. it will work.
Jun 28, 2009 | Intel D845GVSR Motherboard
M-Audio 192 Sound Card _ No Sound comming out
I was speaking to this custom pc company about my identical problem. Turned out that I had the wrong speaker setting in Windows. It was set to 2.0 when it should have been 5.1 and hey bingo, it worked. Not sure if thats what your problem is but sounds the same. Ted
Aug 21, 2008 | M-Audio Audiophile 192 Sound Card
Fix my soiund plzzzzzzzzzz
Your problem is that you still dont install the driver or the driver which you installed its codec is not compatible - go to google and search for the actual driver for your operating system download it and install it - Check which company chipset is on your motherboard whether its realtek or sigmatel search with information over the small audio chip then easy to find the actual driver set.
Jul 15, 2008 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
MICRO PHONE IS NOT WORKING
for one, muicrophone should be plugged into the audio in jack, usually its Pink or has an arrow pointing towards the center of little waves meaning audio in.
If the board is damaged and it just doeant work, go get a Sound card from wallmart, they are pretty cheap, get the Creative 24 bit sound card, i have one and it works great for everyday stuff like this. install it, run the install disk, and make sure you swithc your sound settings from the onboard to the new Audio card. It under START>SETTINGS>CONTROL PANEL>SOUND AND AUDIO DEVICES ( double click). Under the Audio Tab it will have a drop down box to select the audio card or the regular system board audio.
Feb 23, 2008 | Albatron K8T800 (K8X800 PRO LL)...
Gigabyte GA-8I845GVM-RZ Motherboard Logo
115 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Gbenga
Computer Links
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
