Question about RCA T19408 19 in. TV/VCR Combo
TV quits after a few minutes-get a blue screen, no picture and no audio
The tv works fine for up to five minutes, then there is some hash on the screen and just get a blue screen and no audio. There is a faint smell like something is getting hot just before it quits. However, the VCR will play fine, picture and audio, after this happens to the TV.
    Problem Solver:
  • 5 Answers
My best recommendation is to pull the back off it and blow the dust out. Dust is electrostatically attraced to the components inside and acts like a blanket. This causes overheating. Remember to leave your tv unplugged for at least an hour before taking the back off as the CRT (picture tube) will store a charge which can kill you.
Bill
Posted on Jan 21, 2008
SOURCE:
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Power outtage has my dlp hdtv actin weird
unhook everything from the tv and wait for a few minutes, go into the factory mode and do a reset, factory mode code is , mute-182-power
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
RCA T19408 19 in. TV/VCR Combo Logo
112 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
