Question about GE Spacemaker JVM1640SJ Microwave Oven
Display is reading locked.
My 2 yr. old pressed buttons & somehow "locked it". What sequence of buttons do I push to unlock it?
Press "Clear/Off" button for about 5 seconds or longer and it will unlock
Posted on Dec 30, 2007
How do you unlock the panosonic microwave
hi Barbara.
this is what i could find out.
. Press the "Stop" button three (3) times.
or read up more at this link.
You are now ready to use your new Panasonic Microwave Oven. When you first turn on your microwave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . . Press the "Stop" button three (3) times and the "CHILD LOCK" will be turned off.
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How do you unlock the panosonic microwave Google Search
Dec 02, 2017 | Microwave Ovens
How to unlock the samsung microwave
Setting the Child Protection Lock
You can lock your microwave oven so it can't be used by unsupervised
children.
1 Press the My Choice Button and the 5 button at the same time for
3 seconds.
The display shows : CHILD LOCK ON.
2 The display returns to the time of day.
At this point, the microwave oven cannot be used until it is unlocked. To
unlock it, repeat steps 1-2 above.
May 19, 2014 | Samsung SMH7178STD Microwave Oven
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
Its locked
mine just did this too, its the inverter type. I finally found the instructions. It goes in lock when start is pressed 3 times. It can be unlocked by pressing the stop/reset button 3 times, the clock should come back up in the display window. Good luck
Jul 07, 2009 | Panasonic NN-T888S Convection/Microwave...
Says ''Locked'', and we can';t Unlock it.
hi my name is mark, you can try pressing the start button and hold it in for about 5 seconds. without make or model it might work. thanks for your question.
Mar 16, 2009 | Microwave Ovens
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Power is on, but won't cook
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display. You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key. If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call LG / Goldstar customer service at 1-800-243-0000 to find the nearest authorized servicer. There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad. Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean. Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic. If this is what has happened, it would not be covered under warranty, and it may or may not be repairable. A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out with an air compressor or heat, but often that does not work.
Nov 10, 2006 | Goldstar MV-1615 Microwave Oven
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
404 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
