Question about Philips 43PP9202 43" Rear Projection Television
Question on Phillips 43pp92 0217
We are having problems with our red pulling away from our blue in our color on the screen. It is also out of register with the blue and the green. We read on here from another answered post-that the convergence chips can be replaced. However, we need to know what chips correlate with OUR tv. It is a 43 inch. (43pp92 0217). Please advise us so that we can figure out how to fix this problem.
Thanks
Jay and Heather
  • RATBIKER
    RATBIKER Dec 29, 2008
    i ran covergence test and sensor test could not verify sensor in location 1234 what now to get color/pincushion right. phillips model 43pp92 0217,
    color top left and bottom left out of schew.
  • 4 Answers
I HAD THE SAME PROBLEM ,SOUNDS LIKE THE ELECTRIC FOCUS NEEDS TUNING IN .IF YOU FEEL OK WITH DOING IT YOURSELF TAKE THE BOTTOM BACK OFF ,BE VERY CARFUL NOT TO TOUCH ELECTRONICS ON BOARD .REMOVE THE CARDBOARD LINER ,BELOW THE CARDBOARD IS A LITTLE BOX WITH 3 ADJUSTERS ON TOP AND 3 ADJUSTERS ON BOTTOM,TURN THE TV ON A CLEAR CHANNEL,AND COVER FRONT WITH DARK COVER,HAVE THREE PEICES OF CARDBOARD READY ABOUT 6X6 INCHES ,COVER TWO OF THE THREE LIGHTS/CRTS WITH CARDBOARD ADJUST THE BOTTOM ADJUSTERS IN SEQUENCE WITH WHICH CRT YOU ARE ADJUSTING,YOU WILL BE ABLE TO SEE THE SCREEN FROM THE BACKSIDE WHEN COVERED.BE CAREFUL AND GOOD LUCK..DO NOT ADJUST THE TOP 3 ADJUSTERS..GREGG
Posted on Dec 29, 2008
  • 373 Answers
May not be the chips. Try this: go to remote and press 062597 then status to get into the service mode. The menu after that is easy to follow. Hope this helps
Posted on Dec 30, 2007
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Phillips 52 in big screen screen has a red tinge other colors come though but not very bright
Replace the coolant in the CRts a very common problem with phillips. The colors will get very dim and red will become domintae as red seldom needs replacement where as blue and green get congealed and the set will get dim hard to focus and you will see a glowing around green and blue objects. Heres a link to the coolant kit for a phillips which contains the replacement coolant and step by step instructions on CD with pictures on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
May 06, 2009 | Televison & Video
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
HELP! phillips 60PP92902
That model will usually have a couple 6.8ohm 1watt resistors that will get burned open when the ICs go out they are located right next to the ICs and they are all identical resistors often with no color bands just marked with 6R8 1WJ. Lift one side of the resistors out of circuit to check them with an ohms meter. radio shack wont have those resistors but you can get them at the following link.
May 17, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Philips 43PP9202 43" Rear Projection Television Logo
184 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
