Question about Husqvarna Designer I
Grinding sound My Designer 1 begins making a grinding sound form inside and behind the bobbin winder area of the machine after embroiderng for several hours. The machine continues to embroider find. Is this a developing problem that should be look at.
  • crframer Dec 30, 2007
    Yes a needle has broken several times
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Yes, have the machine checked out. The noise is probably coming from the belt and is nothing more than an annoyance. Make sure that you inform your technician that it doesn't make the sound for several hours so that he/she will know how to properly test it.
Please take your machine to a qualified technician. A good cleaning can never hurt but a drop of oil in the wrong place may cause your machine to require major repairs. The shaft bearings in this machine require no lubrication and applying machine oil to these bearings may cause them to seize.
Posted on Jan 13, 2008
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Bobbin winder spinning but not winding thread
Sounds like the thread is not being (manually) wrapped several times around the bobbin before beginning machine bobbin winding.
If the winder is broken, you can always pick up a standalone bobbin winder at the local fabric store or online for ~$25 US.
May 10, 2015 | Sewing Machines
I owe a Topaz 30, lesser than 1 year old. Today I've got problems with the bobin winding. I set it on its place as usually and when I tried to start it and push the ok button, there was a click and than...
I don't have a Topaz, but a Designer 1. I think the bobbin winding setup is similar on these machines. One time I had accidentally pushed too hard on the bobbin winder spindle when I put the empty bobbin on, and the mechanism had gone back inside the machine a little and would not work. I was able to pull it back into place myself without needing to go to the repair shop. Look carefully at your bobbin winder and see if it is in the right place - this might just be your problem and is easily fixed. I am very careful now not to push too hard when I put on the empty bobbin. Also make sure you have pushed the bobbin completly towards the bobbin stop. Does the bobbin winding pop-up appear on your screen?
Nov 10, 2010 | Husqvarna Designer I
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Designer 1 bobbin assembly loose or broken. will not allow machine to function. trying to take cover off machine to remove bobbin assembly so I can use machine until I can get it to repair.
If the bobbin winder spindle is loose and flopping around in the opening in the front of the machine is has come out of the frame that it should be mounted in. Operating the machine with loose parts inside can be risky for the machine and the operator.
Don't take a chance on causing further damage to the machine. The bobbin winder can be replaced without too much trouble and is relatively inexpensive.
May 14, 2008 | Husqvarna Designer I
Sewing Machines Logo
203 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
