Question about Mitsubishi VS-5043 50" Rear Projection Television
Ws 65909 I have been out of town for a week and when I came home the green timer light on the front of the TV is blinking. I have unplugged it a couple of tomes hoping it would reset, but it did not work. The last month or so, the TV has taken a long time to come on or I had to turn it off and then on again to get it to work. Do you know what could be wrong? Thanks.
  • D 85 Jan 21, 2008
    my ws65909 is doing the same thing our power shut off and when it came back on the green light is blinking on the front panel i have tried the rest button with no luck can any one help ???????
  • av8rbum May 21, 2009
    Power went out for 9 hours...came back on and timer light flashes but tv won't turn on. I remember reading somewhere about holding a couple of buttons in on the front to reset the tv. Anyone remember how?
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Posted on Mar 22, 2008
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Power went off in house when it came back on the green light on the front panel keeps blinking will not stop Mitsubishi Bigscreen model ws- 65909
I've got a 65535. When this happens, you can sometimes press the On-Off button for 10-15 secs until the light goes off. If that doesn't work, then unplug the tv for 30 seconds or so, then plug back in.
These sets are known to have power supply issues, and the blinking light may be a coincidence to the power supply failure. It's fairly easy to repair if you know how to solder.
Dec 10, 2009 | Televison & Video
Timer light binking green
U have a DM problem CAPs burned out. download repair manual for your TV.
Jun 30, 2009 | Mitsubishi WS-65909 65" Rear Projection...
We have the dreaded blinking green "timer" light after we unplugged the WS - 65909. We can't get it to reset according to the owner's guide instructions.
The Digital module must be repaired. It is not booting up. When first plugged in the LED in that set will blink for 70 to 90 seconds. That is the amount of time it takes for the digital module to boot up. If it continues to blink past that time the module is belly up and needs to have some capacitors changed in it. Most reputable shops can do this in your home and average cost is between $150 and $250 depending on where you live.
Jun 11, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light on front panel will not stop blinking
gree light in front won't stop blinking after I plugged on the tv ws-65909
Mar 22, 2009 | Philips 9P5034C 50" Rear Projection...
Blinking green light
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
part # 181P734030 (680 uFD, 16V, 105C).
I have done one of these repairs and they are quite difficult so have a tech do this repair.
Feb 14, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
