TP61F90 Won't Turn On
I have a Toshiba TP61F90 that recently started acting up. When I try to turn it on, it makes some clicking noises, and wont turn on. The LED on the front of the set blinks red and green.
I replaced the two large IC chips per somebody else's input, but the same problem exists.
Does anybody have any other suggestions? Thanks
5 Suggested Answers
dwn4lf
SOURCE: toshiba 46H84 tv turned off light blinking
Sounds like a problem w/ the red tube.
Posted on Jan 07, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
ginko
  • 19396 Answers
Slinteriors
  • 8617 Answers
SOURCE: HELP SD TECH!!! I replaced both IC chips as per
The HV cable from the Flyback to the splitter block isnt making the connection thats usually what the 1 blink error refers to the 140 V line. But also check the bridge connectors that connected the two boards together.
Posted on Nov 28, 2009
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
BF wagon made funny noise when starting now won;t turn over...
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: spobd2.com
Jan 29, 2013 | Cars & Trucks
2007 jeep liberty suddenly won't start after
Try starting in neutral. Gear sensor may be heating up and not registering park.
Mar 03, 2012 | 2007 Jeep Liberty Sport
I Have a 97 VTR Firestorm with only 11000 genuine miles on it. Until recently i had no issues with it and it started first time everytime. But this has stopped now. When i turn the ignition the lights...
Hi, Rmn_dan a motorcycle starter relay is an electronic mechanical switch that has a small coil winding around a piece of metal that requires low amperage and thin wires to be activated. When you turn on your ignition switch power 12 volts is sent to the relay coil which in turn becomes a magnetic contact point that pulls a spring-loaded contact point to itself completing an electrical circuit that allows more amperage necessary to be accessed by the starter solenoid which in turn acts in the same way as the relay but on a larger scale with its stronger heavier contacts making available the necessary amperage to turn the starter motor. If your battery has low voltage it, in turn, makes the magnetic contact point weak in trying to pull its counterpart to make a connection. These relays are usually encased in a plastic housing that may or may not be sealed depending on the quality of the product. When activated they will produce a small amount of heat to their metal components which in turn can create the perfect environment for condensation to form depending on weather conditions and how careless you may be with a water hose or sprayer while washing your bike. After a period of time, several months to several years depending on circumstances this condensation is the start button for electrolysis and the slow build up of corrosion which ends by preventing the magnetic contacts in making a solid connection and alerts you to this situation with the customary greeting "CLICK". The relay is inexpensive and needs to be replaced however in a pinch they can be forcibly opened cleaned and resealed with silicone. In a nutshell, motorcycle starter relays take in low amperage and send out higher amperage when activated and for curious minds, the voltage remains constant at whatever your battery reads at the time, this is why a fully charged battery 12.5 volts or better is the best insurance on preventing starter motor problems and increases the longevity of all the starter circuit components.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Thread GP 1200 1997 won start and makes loud buzzing noise
weird electrical problem VTR1000 ORG
Honda VTR1000F Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTR1000F Firestorm Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 11, 2017 | 1997 Honda VTR 1000 F Firestorm
My Toshiba Satellite 4010CDS Laptop never gets past boot. When I turn it on it goes to the Toshiba splash screen and never goes past that. The hard drive makes a lot of noise when I turn it on also. Thank...
What OS are you running?
Did you recently install a new app?
Did you recently install a new hard drive?
Try and do a system restore boot the computer in safe mode with networking to do this you:
  1. Turn on laptop
  2. While booting up press and hold F8
  3. Until you are brought to a boot up option page with different ways of booting up
  4. Click safe mode with networking
  5. When you do this computer will load and click system restore
  6. Restore computer to a previous date when it was working
Sep 18, 2010 | Toshiba Satellite 4010CDS Notebook
2003 Chevy Trailblazer wont start
it sounds like your battery is dead charge it and try again if the starter still clicks it means it is sticking get someone to turn the key while you hit the starter body with the handle of a hammer which will free it of
Apr 01, 2010 | 2003 Chevrolet Trailblazer Ext
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
95 chevy tahoe wont start
test the battery first then go through the ground wires, there will be a few and if one of them have corrosion or are not connected you will not get full voltage to the starter,
Oct 06, 2008 | 1995 Chevrolet Tahoe
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
