Question about Garmin zumo 550 GPS Receiver
No power i cant swich it on i would like help
What should i do i cant switch it on i tryed the reset but dont work and it will not charge i try it in my computer,in the car and i plugged it in is there any anvice
  • Little Lewy Mar 22, 2008
    Yep - same problem. After updating operating software to 4.0 I turned the 550 off. I drove to Zurich airport (easy to get to with road signs to 'Airport', but a pig to find your way home), mounted the Zumo, pressed the Power On button ... nothing. Tried reset procedure ... nothing. Tried removing battery while plugged in to mains ... nothing. This must be a common fault; no doubt Garmin would not acknowledge this. I'm going to try tsking the battery out for longer ...
Remove the battery to reset then put it back on. Happened to me once. At that time my unit was running extremely low on free memory. Free up some memory and problem solved
Posted on Jan 15, 2008
Good day guys, please help its very urgent. my moms friend downloaded a game and now the phone doesnt charge or switch on even with new battery.
Try pressing and holding the power button to see if you get access to power-on/power-off options, or immediately pressing and holding the power-off button when you turn it on. You are looking for the option to start up in Safe Mode. If you can get into Safe Mode, then you should be able to delete the offending game.
Apr 23, 2016 | Samsung Tablets & eReaders
I have a HP630 but my pc don't want to swich on
disconnect the power supply, hold down the power button for 1 minute and re insert power try switching on if not try pushing the power button and the disc tray button at the same time
Nov 20, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Power windows do not work. replaced the main swich. have power to swich and coming out of switch. i cant believe all 4 window motors are fryed. power door lock switchs do not work either!
this sounds like a fuse problem. In the owners manual( under fuses and relays) it will tell you which one it is. its probably a 10 or 15 amp fuse. try this first, and if not, let me know. hope this helps
Jan 29, 2011 | 1999 Buick Century
1999 blazer heat on the floor dont work just blows out the defrost. heat works good just cant get it to blow on the floor. is this a problem in the swich or vacume
Most likely the vacuum. The (door) that switches the heat from floor, dash, defrost, isn't switching. The door could be stuck and even though it maybe trying switch, it can't from being stuck or in a bind.
Jan 03, 2010 | 1999 Chevrolet Blazer
My Phone does not switch on.
Perform a hard-reset.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
Please rate...
Sep 12, 2009 | O2 Xda Atom Exec Smartphone
My Menu is locked and asks for a password which I've forgot?
Is that even possible to sett a password on a swich?
I couldent find anything about that.
Is there a "reset" button back on the swich? if there is push it and hold it for at least 5 seconds, that will remove all possible passwords.
I found the manual for it though,
http://www.startech.com/Data/ProductManuals/SV211K.pdf
Dont know if that helps you, but its the best i can get you.
Nov 26, 2008 | StarTech.com StarView SV211K 2-port KVM...
I cANT ON MY PLAYER
when you reset it and turn it on try waiting a bit.
then look and see if the unit looks like it's got a light on.
if it does hold the power button until it powers on.
then try holding the power button until you see goodbye to turn off the unit.
if that doesn't work when you turn it off and the keypad light is still on then reset it again.
hopefully that works..... good luck
May 25, 2008 | Coby MP-C7085 MP3 Player
Help with my mp3
plug your usb to your computer and try to see if your computer can detect it.
then you can try and reset it again.
good luck
May 20, 2008 | Coby MP-C7085 MP3 Player
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Garmin zumo 550 GPS Receiver Logo
129 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
