Question about Bissell 6700 Butler Revolution Bagged Canister Vacuum
FAN PROBLEM??? good morning! my vacuum smells like burnt rubber (fan perhaps) but I can't find how to get into main part of the vacuum. it's just very rounded with no latches or screws to get inside where the motor, belts and fans would be located. can you help me? thank you
    President:
  • 1,673 Answers
There isn't any belts, and the fan wouldn't be rubber, so not sure what you are smelling. Maybe this picture will help you.
Posted on Jan 22, 2008
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
Vacuum cleans properly,however smells like rubber. Nothing is caught in belt
You need to replace the vacuum belt. Even though the belt may look fine it is probably stretched or worn and slipping on the motor shaft and that is why there is a burnt rubber smell. You can get replacement belts here:
Replacement Vacuum Belts
Oct 31, 2009 | Vacuums
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The motor is running, the roller brush spinning rubber smell
Sounds like the main suction pipe is blocked.
Unplug, and in good light - see if you can see any obstructions in the pipe from the prush area to the bag (in a bagless vacuum) or to the fan in a bag model.
Aug 04, 2009 | Vacuums
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 6700 Butler Revolution Bagged Canister Vacuum Logo
69 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
