There is small switch located at front circuit board that is not working properly and causing "cover not open" message. Take off LCD cabinet section then remove front cabinet section, remove screws on circuit board and turn it to see that switch. There can be lose connection on switch terminals or switch is not being pressed properly with lens cover lever. Please check it carefully. Thanks.
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam DCR-HC30 Mini DV
When you try to record, it gives a beep beep beep about 4 times and a small orange light appears. I...
(More)
When you try to record, it gives a beep beep beep about 4 times and a small orange light appears. I replaced battery.
on both the lcd screen and the viewfinder the image is all screwed up with lines up and down the...
(More)
on both the lcd screen and the viewfinder the image is all screwed up with lines up and down the screen.
