My calibration on my ds, doesn't seem to work. i go to the settings and the yellow icon/calibration icon and it stats up. I press all the squares and it just keeps going going and going! I've cleaned it, but theres been no let up please help
Mines the same. but i click the first square in the nentre of it then i click the centre of the second square and on the last 1 i go two squares across and it says i colabirated it. bit gay but i want it fixed
Plug it into the charger first.try calibrating the touch screen. you can get to the calibration menu without touching the touch screen. First, turn off your system. Hold down L+R+X. While holding these buttons down, press the power button. This should take you to the touch screen calibration menu. (See Nintendo 3DS Operation Manual, Page 15) If it doesn't work,you need to replace the bottom screen.
please note that all games dont require the bottom screen
Turn the DS on without a DS card inserted (or with Auto mode turned off).
Touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon.You will then be taken to the calibrate screen.
Touch the small red squares on the screen as they appear.
Press Confirm amd exit menu.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
ICON CALIBRATION INSTRUCTIONS- INCLINE 1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration. 2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. 3) Press either incline key and the incline will calibrate automatically. 4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Remove the battery at the back of the ds to reset it, to do this you will need a small phillipes screw driver, and a small knife to flip the battery out.
When the battery has been removed turn the ds over and and rub your finger quite hard around the far edge of the bottem screen all the way around, do this a few times.
Turn the ds back over and re-insert the battery and the cover. Turn the ds on and set up your name etc, once set up go to the little icon on the bottem of the screen that looks like the ds, then go to the yellow icon on the right to calibrate the touch screen, if all goes well you should now have the touch screen back. Post back if not, you may need to open the ds and check the connector on the logic board.
try to re-calibrate your stylus..remove any game card..then go to system settings..you can see it on the lower screen like nds icon...then select the calibration icon...icon on your right like a cross hair..then restart nds after you calibrated..try your game...hope this help
If you would like to calibrate your screen... Turn the DS on without a DS card inserted (or with auto mode turned off). Then touch the DS icon in the bottom middle of the screen. Press the far right yellow icon, with a crosshair in it. You will then be taken to the calibrate screen. Touch the small red squares on the screen as they appear.
Im really bad at describing things but I hope this helps xD
Please don't for the love of pete go buy another screen.You will only have the same problem like 50 times over.
Since the touch screen isn't working use the rrow keys and the "A" button to selct everything
Take the game out of the DS and turn it back on. Go to the options menu when the DS is on the main Screen(If you dunno what the menu icon is it's at the bottom of the screen about the centre.. the icon is a cute mini DS)
Once you are on the options menu go to the yellow screen and select it ... This is where you calibrate your DS.. i.e make the touch screen work again in most cases.
You should probably calibrate the screen weekly cause the DS is lazy and doesn't remember where the touch sensors are ..
Turn the ds on without a game in it and go to the settings icon (looks
like a tiny ds) on the bottom middle of the screen then go to the far
right yellow icon and it will re-calibrate the touch screen and let you
know if calibration was a success.
I think your touchscreen must not be calibrated correctly. Turn on your ds without a game and go to the little tiny ds a the bottom. Then click on the yellow orangish icon and it will start calibration. Just touch the marks with the target things to calibrate it.
When you turn on the ds, go into settings (the center icon at the bottom), the press the yellow icon. I assume you got to that part.
Now you have to tap the calibration points; as you touch them, they should move to the next point (three altogether). Does that happen?
Next, you should be able to test it at four points. They will turn blue when you touch them. Does that happen?
If there is no response when you do this, your digitizer may be faulty.
The DS will reset to factory if you remove the battery. You need a small phillips screwdriver for that, on the bottom of the DS.
