Before you start thinking about your motherboard, let's rule out your harddrive.
Go online and Google "emergency boot cd" and choose a product that works for you. Many have "demos" you can use with limited capability, but that's fine. You will need to take the .iso file and burn a CD with it. This will create a bootable CD.
You will need to setup the computer to boot from a CD by going into BIOS and setting the boot sequence to CD first. If you don't know how to do that, here's a good article... http://www.cites.illinois.edu/security/antivirus/bios.html
Using your newly created CD, put it into CD drive and start boot up. If your computer boots normally, you have a harddrive tht has failed. If not, you may have a motherboard issue, or possibly a different hardware issue that may require professional assistance.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion zd8000 PC Notebook
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into...
(More)
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into hibernation and now it will not turn on at all
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list...
(More)
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list just disappear and are not to be found.
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple...
(More)
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple of weeks has made its way down the screen. This is a new laptop and I haven't taken it anywhere and handle it with great care. Any ideas as to what I can do other that ship it back to Toshiba?
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success....
(More)
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success. color is off and picture distorted
I have a toshiba with now 2 lines running down the middle of the screen, present upon startup,...
(More)
I have a toshiba with now 2 lines running down the middle of the screen, present upon startup, before windows, and, the second one just appeared today...is my screen going bad? how would I replace?
