I have a kitcheaid kesc307hw0 slide in stove. The infinite control switch controlling the dual frt...
(More)
I have a kitcheaid kesc307hw0 slide in stove. The infinite control switch controlling the dual frt burner is not functioning properly. Does any one know what each wire wires connected to this switch does or what they are called. I purchased a new replacement switch from Kitchaid aid. However the new switch looks alittle different from the original switch . All the terminals are in different locations. Can some help with the wiring codes for each wire? Thx
the temputure probe keeps alerting on the touch pad. This is the second time it was replaced and it...
(More)
the temputure probe keeps alerting on the touch pad. This is the second time it was replaced and it is doing it again.
I have kitchenaid superba built in gas range. The glass has many stains on inside. would like to...
(More)
I have kitchenaid superba built in gas range. The glass has many stains on inside. would like to clean and perhaps get better seal to avoid more stains.
I have a Kitchenaid stove model # kEsc307hbsh It will not let me set the tempture for over 250...
(More)
I have a Kitchenaid stove model # kEsc307hbsh It will not let me set the tempture for over 250 degrees what is the problem
