Toshiba HD-XA1 DVD Player
Problem for Toshiba HD-XA1 DVD Player
Their is a disc stuck in my Toshiba HD-XA1
By artnsoul88 on Oct 22, 2009
their is a disc stuck in my Toshiba HD-XA1 plyer.All it says is ''welcome''.I tried to unplug it but still did not work
Best Solution
posted on Oct 22, 2009
Very Helpful)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 87%, 1020 votes
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire,a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
To open the DVD player top to remove the cd/dvd manually--
  • Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
n Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
n Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
n Never work on an electrical device that's still plugged in.
n Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Incredible!it worked,did not know there was a hole there....THANKS! " - artnsoul88
Popular Solutions for Toshiba HD-XA1 DVD Player
Questions and Unsolved Problems for Toshiba HD-XA1 DVD Player
Do you recommend Toshiba HD-XA1 DVD Player?
Answer
Answer
My unit when I put a dvd in to watch, the door will open about 3 times before it will stay closed... (More)
Answer
i have thetosheba satalite p305-s8910.dvd super multi drive it doesnt reconize any cd's or dvd'd.i... (More)
Answer
toshiba dvd player is playing fine, but the disc is not retrievable. when "open" is... (More)
Answer
The VCR is working fine but the dvd drive will not even open most of the time. When it does open and... (More)
Answer
Recently my toshiba dvd player complains about bad discs or no disc. The discs work fine on my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
