Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't start/lights on
Ran couple loads of laundry without problem and then washer stopped working. Lights come on and the time changes with the various settings. Door is shut tight, have turned breaker on and off, press and hold start button.......nothing happens.
  • frue Dec 30, 2007
    Thanks for your note, unfortunately, nothing changed after I tried your suggestions. Believe me when I say the door is firmly shut!! The soap drawer is closed all the way. It almost seems like the "start" button is not communicating to the system itself. If I take off the panel, would it be easy enough to tell if there is a loose connection? The washer was working fine and then just stopped.
  • Anonymous May 23, 2008
    The start button will not start the washer. All other buttons work the door is shut tight, the soap dispenser is shut tight. I have unplugged the machine and tripped the circuit breakers,nothing... it is if the start button is not registering to start the machine. My machine is 5 years old
  • 1,314 Answers
Ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Posted on Dec 30, 2007
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
Try washing bedding, towels, undergarments,
contact using the ActivFresh
1. Load your washer.
2. Close the door.
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
Apr 05, 2013 | Washing Machines
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should's a link to check hope it helps
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have owned the Whirlpool Duet 9750 for 2 days. The first 5 loads of laundry went off without a hitch. When I put in a couple items for the 6th wash, when I hold in the Start button to start the cycle,...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$##
Jun 01, 2010 | Whirlpool LSW9750 Front Load Washer
When I start a load of laundry, it gives me a F1 code on it. I hit stop and start it again. The first time it did this it worked the second time. This time I had to change the setting to Express Wash...
call this # 1 800 847-9083, but have your Model and Serial # ready, they are located on the back wall below the bottom of the door opening.
set a time for them to change the control box.
Jan 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
285 people viewed this question
Dan Webster
Dan Webster
Sal De
