The thermostats will go bad from time to time. these can be ohm out to see if they are faulty. research your model/name brand dryers troubleshooting guide, model/name dryer not heating, test to preform. this should help you isolate the problem.
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You were told wrong...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
check out this electric no heat tip...
