Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Oil leaking I have have my Kitchenaid stand mixer for about 6 years. I am happy to say that all has gone well up to now. Let me tell you here that i take excellant care of my Kitchenaid mixer because i waited until i was in my 40's to get one.  :) I was getting ready to use my machine when i notice oil coming down the paddle. I of course had not even started the machine up. I tilted the machine head in the up position to have a look. Yes! it was oil. This had never happened before. I did use the machine. YES i did. I needed it and i had to take a chance. I have used it a few times over the last few mths and on occassion i find small amounts of oil on my finger. I of course check the machine all the time. Here is the problem, (1) i need to have the schematic of this machine before any opening of it can be done. (2) I called Kitchenaid to try and find a repair person in my area. Well i was shocked to find out that i would have to drive three hours to have my machine even looked at. Then drive 3 hours home and wait for them to tell me how much the repair woould cost only to drive back again, you can see the problem here. So i would also like to know if there are any repair persons in the Detriot Michgan area. I live in Canada but Detriot is a lot closer. I sure hope you can help. Wishing you a happy Holiday And happy New Year Heatehr
See this thread. http://www.fixya.com/support/t125253-mixer_leaking_oil
There is a link to a schematic drawing of the unit listed as well. Just take it apart. Inspect gasket, clean up some of the liquid oil put back together. After taking this thing apart it very easy to see why it would leak. There is 10x the amount of grease needed. Hope this helps.
Posted on Feb 07, 2008
My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
Mar 30, 2010 | KitchenAid KSM103 Professional 5 Series...
My stand mixer was stored on its side and leaked oil.
Called the Kitchenaid toll free number and found a local authorized repair center. Not a fixya solution, but at least a solution.
Oct 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Jul 09, 2009 | Food Mixers
Leaking oil
Jun 27, 2009 | KitchenAid Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
149 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
