Home | GE | GSS20IEP Side by Side Refrigerator | Ice maker and water dis...
GE GSS20IEP Side by Side Refrigerator
Problem for GE GSS20IEP Side by Side Refrigerator
Ice maker and water dispenser water supply is cut
By linda_simms on Oct 22, 2009
Ice maker and water dispenser water supply is cut off. Plumber checked the supply line and it is operational. The tube inside the refrigerator is crimped behind the vegetable drawer. I have a service contract but, wondered if I should check something else before calling.
Not sure about the Model number because I am at work.
Best Solution
posted on Oct 22, 2009
Very Helpful)
localwonder
Rank: Guru  GE Refrigerators  Expert
Rating: 92%, 2767 votes
OK, I would check the supply tube, to see if it may be frozen. if so, you will need to defrost it. This will occur if the inside temp is set to a non-manufacturer specifications(temp is to low). Now, if the tube is not frozen, this will lead to a failed inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE GSS20IEP Side by Side
Questions and Unsolved Problems for GE GSS20IEP Side by Side
Do you recommend GE GSS20IEP Side by Side Refrigerator?
Answer
Answer
ice maker works great, water line quit dispensing
Answer
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice... (More)
Answer
converting one ice-maker from one fridge to another
Answer
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE GSS20IEP Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
