Apple Mac OS X Leopard 10.5 Full Version for Mac (MB021Z/A) Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My attach iss not working in my e-mailI pressed something and now it won't load
Anonymous
Level 3:
Master:
  • Master 404 Answers
  • Posted on Oct 22, 2009
Anonymous
Master
Level 3:
Master:
Answers
404
Questions
Helped
125422
Points
1031
U ruined it, u fix it
2answers
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
1670: unable to load module d:iss setup.dll,error code:193
this game was not released for the PS3 and may not be compatible with the newer hardware.
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
1helpful
There is something wrong with my Dell Desktop Optiplex 210L PC..?
Start running a thorough virus scan.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Uninstall any extras like those pushy toolbars, and add-ons.
Our new hp monitor won't restart after computer is taken off sleep mode the screen will show a partial screen saver but it won't display icons until you turn off monitor and turn back on
is this only your monitor or is it your computer as well
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
1helpful
I have a rexel odyssey heavy duty stapler but the spring has popped out, how and where do I attach it back on?
Rexel Odyssey heavy duty stapler: The pring that pushes the staples into position can come losse if the stapler iss dropped. It's difficult to work out how to replace it! However, there are only two "lugs" that will take the circular ends of the spring. One obviously fits to the sliding staple retainer. The other to the back end of the pressed-metal inner body. However, to work, the spring must be threaded from this point along the pressed metal parallel-sided inner body back through a slot and over a rounded bent piece (shiny from prvious friction) and back down to the sliding staple retainer. It's trickey to do, but that's where it has to go in order to provide forward tension when the Stapler is closed.
1helpful
I have a Canon T50 film camera and one of my lenses (a 50mm) won't go back on. It's the lens that was attached when the camera was given to me, but now it won't go back on.
If you are putting it on correctly and it won't attach then something on the lens mount must have been damaged. Take the camera and lens to a camera or electronics store that does service work to see if it can be repaired.
Jul 30, 2011 • Cameras
My acer erecovery management won't load it just says please wait a moment and I am not sure of what to do. Help?
Try reboot pressing F8 repeatedly....try accessing recovery from there. If no recovery there then boot into safe mode and try recovery there. This will only load windows core services and basic hardware drivers required to use system. If this does not work then you might have disk errors and check disk or sfc scannow will need to be initialized. you can run these from a command line option. To do this you will have to open a command promt as administrator and type without quotation marks " sfc /scannow".
For check disk assuming the primary drive is C:\ type "chkdsk C:/r" or you can use the /p switch to perform an extensive scan (do not use both /r and /p within the same command as it iss not needed). This utility might require you to enter "y" or "n" for yes or no to reboot the system to perform the scan of the drive as it will need to be unmounted first. Follow the instructions and insure you have from 30min......to possibly several hours for it to perform the needed scans.
Hope this helps........
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
1helpful
Tracking ISS
Two Line (orbital) Elements (TLE) loaded from your computer to Autostar will do it. You can get the TLE from www.heaven-above.com ISS orbit
1 25544U 98067A 08223.18921414 .00008400 00000-0 64811-4 0 240 2 25544 051.6411 098.9613 0010451 052.2327 040.0128 15.72906000557033 This was for 08/10/08 and following days.You have to insert the TLE into Autostar by way of the #505 cable set.Then follow the instructions in the manual for a satellite. Anticipation and practice is everything.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
