Question about Gemini 1 Device Universal Television Remote Control
Gemini cl033 i am using a gemini cl033 remote for a phillips dvd player and need to bring up a setup menu. I cannot find a button on the remote that does this?
  • Anonymous Mar 03, 2008
    instruction to use for codes
Sit on it
Posted on Mar 23, 2008
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Code available for free at this address:
Hope that helps,
Mar 17, 2008 | Gemini Sound Products SBR3B Remote Control
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Remote instructions
Have you tried this,
They work for remotes with (CL033) maybe it'll work for you?
Sep 17, 2007 | Gemini 1 Device Universal Television...
Televison & Video Logo
189 people viewed this question
Top Gemini Televison & Video Experts
Tom Chichester
Are you a Gemini Televison and Video Expert? Answer questions, earn points and help others
