the reason for an admin password is so not everyone can down load, or change program files important to the computer running correctly. you can set up different user accounts with varying degrees of access, each with their own password if you wish. from the start menue, go to contol panel/ user accounts
What if you forgot windows 7 password by accident? How to crack windows 7 password by yourself? Try this wonderful SmartKey Windows Password Recovery as soon as possible. The same as windows 8 password recovery. Step 1: Download and install, run the program on a unlocked computer. Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program. Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Try to recover Admin password with Windows Password Recovery 6.0
an easy-to-use tool designed for resetting local administrator and user passwords on any Windows system. If you have forgotten your password, or are locked out, or you do not have access to the password of the system. It is the most effective product on the market.
If you have forgotten your BIOS or Hard Drive Password for this model, there is a master code that you can obtain from Dell Support. Simply call, Email, or use Online Chat from http://support.dell.com and give them your Service Tag, and they can help you out from there. If it is a Windows profile password you have forgotton, try accessing the Administrator account from Safe Mode (Press F8 at startup), and remove the password for the user account from Control Panel, User Accounts.
Forgot Windows XP password? The first thing which you check is whether you forgot windows xp login password or not. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forgot your user account password then try this: Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen. Windows XP and further versions also provide another method to recover forgotten Password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. Or try free program called Ophcrack or Windows Password Recovery Tool 3.0.
Boot your computer into Safe Mode. It sometimes varies, but the typical way on most WinXP
based machines is to strike the F8 key during P.O.S.T. Once the drivers load you need to
access the Command Prompt. START / ALL PROGRAMS / ACCESSORIES / COMMAND
PROMPT. A new window will appear.
At command prompt, type "control userpasswords2" and press Enter to open the Windows 2000-style User Accounts application.
On the Users tab, clear the Users Must Enter A User Name And Password To Use This Computer check box and then click OK.
In the Automatically Log On dialog box that appears, type the user name and password for the account you want to be logged on each time you start your computer.
This is also an opportunity to set a new Administrator password.
