Question about Avanti FF1101W Top Freezer Refrigerator
Hotpoint hts17gbserww the freezer is working fine but the refer is cool but not cold milk will last 2 or 3 days.
  • Anonymous Nov 07, 2008
    the fan is running the evaporator coil is not froze it has some ice allover but it looks normal the compressor is running the condenser fan is running too
  • Anonymous Mar 12, 2014
    I have put thr fridge on the coldest and everything in the fridge is just above warm. I have tried cleaning the vents and keep a good handle on the fridge but still does not get cold enough. It's to the point where a 1.4 gal of milk will only last 2 days before going bad
  • 283 Answers
The problem you describe could be caused by a lot of different things. To start with, is the fan in the freezer running?
Posted on Dec 31, 2007
Hi my side by side wards refrigerator and freezer doesnt always get cold enough some times it will make ice and keep milk cold and other times wont make anything cold. it spoils milk one day and next day...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
Jun 14, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Freezer has to be thawed out every 2 to 3 days. The refridgerator side isn't staying cool enough to keep milk from spoiling. It is a Hotpoint Model #HSS25GFTA WW and is only 2 1/2 years old. It is a side...
Could be multiple problems. First, check the freezer compartment and make certain that the freezer fan is running. This fan moves cold air from the freezer compartment to the refrigerator. If it's not running, inadequate cold air gets to the refrigerator.
Your having to defrost manually sounds like there could be a problem with the defroster circuitry; however, check out the fan operation first.
The fan should be at the top of the freezer. There is probably an access panel you can remove to see if it's turning. However, you should be able to hear it if it's turning.
If the fan is not turning, you will need to remove it and replace it.
Oct 11, 2009 | Refrigerators
Refrigerator warm, freezer is fine.
Hi: It is either the defrost heater (most likely) or the defrost timer. The airway to the fresh food is clogged with frost. I doubt your freezer is packed as you could put your hand on the vent. If you block the vents this can cause the problem also. Check the defrost heater and replace if necessary. It is a wire coil in a glass tube. if the coil is broken it is bad. Look at your parts list or on line at Sears Parts. to find out where it is. I hope this helps, Jeff
Jun 01, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Avanti FF1101W Top Freezer Refrigerator Logo
502 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
