Home | Nikon | D200 Body Only Digital Camera | I use a Nikon D200
Nikon D200 Body Only Digital Camera
Problem for Nikon D200 Body Only Digital Camera
I use a Nikon D200
By gabalex2 on Oct 22, 2009
I use a Nikon D200 in my photo studio. In the past week, my issue has occured twice, both times very intermitently. I'm in the middle of a session, all it going well and camera is functinoing properly, and is also triggering my strobe lights as it's supposed to. But for some reason unknown to me, the camera will suddently quit recording the images to the disc. It is still functioning as though it is, but I cannot see the images on the LCD screen and there is no record of them on the disc. I switch the disc out, and the camera functions properly. After the session, I switch back to the original disc that was in when the situation first occurred. Images record just fine. Originally thought it was disc error, but I got rid of the disc from the first instance. It has now happened again. Can you help?
Comments:
Oct 22, 2009
- I can reset the camera if you think that's the problem, but I use the camera daily for hours on the same settings (the only things I change are ISO, aperture, shutter speed, etc.) and all within reasonable numbers. The error occurs while I'm using the camera in normal settings, and have already taken several pix in those settings. It just quits recording the images with no indication as to why, and with no changes to the camera settings from my end.
Solution #1
posted on Oct 22, 2009
Somewhat Helpful)
micromaster
Rank: Wiz
Rating: 82%, 749 votes
Let me know if you have done soft reset on the unit.
Kindly first reset the unit, in able to restore it on the default settings, it sometimes happen that you have done wrong settings and result to camera malfunction.
Hope this helps
Solution #2
Not Rated)
gewiz
Rank: Wiz
Rating: 84%, 78 votes
I use to have that camera and I had issues with the Microdrive,
Do you have any problems when writing to flash media ?
Look at the contacts etc, are they clean and does the drive fit tight?
If so I suggust you try another microdrive and if the problem still there it the camera or otherwize the microdrive, getting hold of another microdrive is the issue here ?
Regards
GeWiz.
Popular Solutions for Nikon D200 Body Only Digital
Questions and Unsolved Problems for Nikon D200 Body Only Digital
Do you recommend Nikon D200 Body Only Digital Camera?
Answer
Answer
Can't use bracket button when both Raw and Fine setting are selected...What do I have set wrong in... (More)
Answer
how do I find out how many pictures my Nikon D200 has taken
Answer
Hi my Nikon D200 shutters every time I turn the camera and some time before you press the shuttre... (More)
Answer
The "S, CL, CH.." spindle of my Nikon D200 seems to have slipped about 90 degrees to the... (More)
Answer
"Off" is flashing in lcd display. Why?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D200 Body Only Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
