Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultra Care II
Our clothers washer agitator doesn't move properly...like it's loose or something.
Any advice?
Brent McClun
  • 4 more comments
  • susieyruben Jan 05, 2008
    Hi we have the same problem, after doing a big load of towels I noticed the agitator moves fine when there is only water but no clothes in it but once filled with clothes the agitator moves very little unlike it used to and seems loose. Any advice please!?
  • jas8843 Nov 18, 2008
    My ulltimate II tub acts like it isn't screwed in and makes a lot of noise when washing. When empty, I can move the tub freely (all over the place). How do I put in this part.
  • Anonymous Dec 28, 2008
    my pump is leaking how do I do you remove it to replace it
  • paru0615 Feb 01, 2009
    The top part of the agitator is loose and not moving the clothes around. How can I take it apart to see whats broke
  • Anonymous Apr 21, 2009
    top agitator is not moving , bottom is . how do i repair?
  • SwellMel Apr 23, 2009
    I have the same problem. Anyone find anything out about it?
How easely can it be changed. Tell me what to do. George
Posted on Jan 08, 2008
  • 589 Answers
I believe this is a similar model to mine, which did the same things. This is a direct drive style (no belt). What possible happened is the coupling in between the motor and transmission has broken partially, and it "grabbing" only under a light load. It's a relatively inexpensive (under $5) part, and can be changed pretty easily.
These couplings can be found on Ebay:
http://cgi.ebay.com/285753-Whirlpool-Washing-Machine-
Motor-Coupling-Coupler_W0QQitemZ170183665420QQihZ007QQcategoryZ20714QQss
PageNameZWDVWQQrdZ1QQcmdZViewItem
If this link doesn't post correctly, just search for "whirlpool coupling". Good luck.
I have a Whirlpool Ultra Care II. Serial No. CK2481971 I need to know how the top agitator works. Should it be moving with the bottom part of the agitator?
Try and turn it by hand . If it turns one way free and not the other way it is ok. If it turns both ways the rachet dogs are probably worn.
Oct 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My agitator on my whirlpool washer doesn't work properly and that keeps the clothes from getting clean. it seems as something is loose,the bottom part works somewhat but the upper of the agitator's not...
The top portion of the agitator is designed to go in only one direction. The purpose is to keep the clothes moving from top to bottom of the basket. When this "ratchet" action fails to occur, it's due to worn "agitator dogs" (part # 80040) usually caused from overloading. It can be a do it yourself repair, or a very inexpensive service call if a professional is used.
http://www.servicematters.com/docs/part_instruct/285747.pdf
Jun 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate Care II problem
IF THE PROBLEM WITH THE AGITATOR IS THAT IT DOESNT HAVE THE POWER AS BEFORE IT SOUNDS LIKE THE AGITATOR DOGS NEED REPLACING.GOOD LUCK
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator
aleethie In order to help you better I need the complete model number of your washer. You can find it under the lid on the frame. Gendos
Jul 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,735 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
