Samsung PCN5425R 54 in. Rear Projection Television
Problem for Samsung PCN5425R 54 in. Rear Projection Television
Picture is completely warped. How can I adjust
By fernando_rfa on Oct 22, 2009
Picture is completely warped. How can I adjust convergence
Solution #1
posted on Oct 22, 2009
Not Rated)
Russmann
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 89%, 77 votes
If you go into the menu and the convergence doesn't move, you must repair the convergence circuit. The way you do this is by: First, disconnect power and remove lower rear cover. Next, with a powerful light and a good pair of eyes look very closely at the circuit board where the STK392-040 convergence chips are located. You will need to change these i.c.chips using soldering/desoldering equip. Also, you need to have an ohmmeter to test the 1.5, 2.7 and 3.9 ohm resistors which commonly change in value or burn up. Change any that don't check very close to appropriate value. Finally, after changing all these parts. Make sure you clear any confused data from the eeprom by entering the service code (mute,1 8 2 power)at time of turn on after completing repair. One other note; this set is known to have had problems with coolant leaking onto the circuit boards. So make darn sure that there aren't any drips coming from the tubes. If you call a repairman, expect a 250-350 u.s. dollar repair. Good value considering the time it took to get experience on these units. Good luck Russmann.
Was this helpful?
Yes
No
Popular Solutions for Samsung PCN5425R 54 in. Rear
Questions and Unsolved Problems for Samsung PCN5425R 54 in. Rear
Do you recommend Samsung PCN5425R 54 in. Rear Projection Television?
Answer
Answer
tv has bright spot in the middle with yellow around the edges.
Answer
my samsung pcn5425r, the blue color is almost gone. it's heavy on red and green. every show i see... (More)
Answer
I have a samsung pcn5425r that turns on but there is no picture
Answer
Can you tell me if the Convergence IC fix is an expensive one? You say it is detailed: can you tell... (More)
Answer
samssung 5425r went blank and wont turn on ,power light blinks 10 times
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , OK
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
