Question about Canon XL2 Mini DV Digital Camcorder
Cleaning tape jammed in canon xl2 camcorder
I've just inserted a head cleaning cassette into my Canon XL2 and on ejecting it, it would slide out from the internal sleeve? Can you advise?
Regards
Jazz57
    Sergeant:
    Champion:
  • 317 Answers
Take the camera to a reputable camera shop, there is honestly no way to do this at home, if you touch the video heads by accident, or accidently move something, it could spell big trouble. Also I to have an XL2, and canon might be willing to fix this for free from what I understand about their customer care plan (Best Regards)
Posted on Jan 09, 2008
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
I got the problem with my canon XL2 since last 3 months ago. The tape cannot unload sometimes. During recording and run out with tape, try to change with the new one but the cassette compartment cannot...
that is could be the cassette in switch or door swith inter mitent contact, or the mode switch for the mechanism position....
or a good clean up of the mechanism...
hope that will help you
regards allan
Sep 02, 2010 | Canon XL2 Mini DV Digital Camcorder
Canon xl2 will not take the tape it says remove tape in viewfinder.camera is dry whats going on here
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Mar 15, 2009 | Canon XL2 Mini DV Digital Camcorder
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Canon xl 2 says heads are dirty. use tape cleaner
You have a heavy clogged condition on the heads. Manual cleaning of video heads and tape path by trained technician is $99 at www.camerarepairjapan.com. Once cleaned by technician, you can continue maintain head cleaning with tape cleaner for once in a while when needed. Run the tape cleaner not more than 5 seconds. -James
Jul 13, 2008 | Canon XL2 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sound Problem
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Dirty Replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Canon XL2 Mini DV Digital Camcorder Logo
253 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
