Question about JC Whitney - Pyle High-power Woofers Car Speaker
1991 Dodge Dynasty 6 cyl.
Car starts but will only run a few seconds then suddenly shuts off.
It could be a fuel-pump ready to die.....or the fuel filter needs replacing.....or could have a vacuum leak. Sounding like that it's starving for gas...it's getting a little...but just enuf to run for a bit. I would start w/ the fuel system. Hope that helps you out for starters.
Posted on Jan 01, 2008
After i start my dynasty and run it for a while and then shut it off it wont start right back up. I have to wait for at least an hour before it will start back up. I honestly don't know whats wrong.
Back in the old days that was a coil problem. I am not 100% sure of the name now - but i replaced the "electronic igniction control module"?, and that fixed it. Pretty simple. It's right on top, has about 6 easy to get to bolts and a plug. It's square. I got it from the local NAPA store.
Sep 06, 2011 | 1991 Dodge Dynasty
1991 Dodge Dynasty LE car will suddenly die while driving. If I pull off the road, turn the ignition off and restart it- will start but when I put it back in gear the engine stalls again. After five or ten...
Sounds like you are having a fuel problem with the fuel filter. If you have not had your car serviced in quite awhile i would do so. At least change the fuel filter and check the air filter as well. Hope thias will help you.
May 26, 2010 | 1991 Dodge Dynasty
1991 dodge dynasty 3.3L-no power to fuel pump & replaced 2 things
fuel pump shut off swiches are normally in the trunk refer to your manual to find out if you have one or not.
Jun 20, 2009 | 1990 Dodge Dynasty
Fuel pressure drops immediately to zero when engine is shut off.
I am not really familiar with the setup there but I'd be looking for a second relay to kick the pump on when cranking.
Jun 05, 2009 | 1991 Dodge Dynasty
1991 Dodge Dynasty interior dome lights won't shut off
First, check the dimmer switch (should be the same as the headlight switch) and make sure it is not turned all the way to the right as that will turn on the overhead light.
If you are sure the door switch is fine, then I would replace the dimmer switch.
May 14, 2009 | 1991 Dodge Dynasty
Car wont start and acts like it aint getting no gas
change fuel filter.check fuel pressure.
Apr 06, 2009 | 1991 Dodge Dynasty
When I hit a bump in the road with my 1991 Dodge Dynasty all of the interior lights come on and will not go off even by shutting the car down. You have to pull the fuse then after a few hours put it back...
I would check the button switch's on each door, If you have a damaged door or one that has worn hinges maybe it has enough movement on the bumps to allow the switch to turn on the lights
Mar 16, 2009 | 1991 Dodge Dynasty
Dodge dynasty electric fan doesn't turn off
On some vehicles, the fan will continue to run for a short time after turning the car off. But if it runs for more than 5 minutes you may have a bad sensor or stuck relay
Mar 06, 2009 | 1991 Dodge Dynasty
Car Audio & Video Logo
60 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
