I AM TRYING TO DELETE A SENSOR AND ADD TWO MORE. HOW CAN I DO THIS? I CANNOT FIND HELP IN THE MANUAL. WHEN I PUSH DELETE ON THE START MENU THEN SENSOR/REMOTE ON THE MAINMENU I GET THE RESPONSE OF "FUNCTION UNAVAILABLE". THE SAME HAPPENS WHEN STARTING WITH ADD IN THE START MENU.
-   hi i need to know how to programmed the timer test to cms -   gautamkumar4
Mar 25, 2008
-   I need to know how to delete a sensor, the motion sensor that was installed in the main room was removed and now the panel box chirps so I need to delete the motion sensor programming.-   alggor
go into the simon, 64321 tech code then delete and the sensor button until it tell you which one you are on and then hit done..that deletes then to ad back depending on which sensor you are using , by hitting add then sensor and going to the room or door or what ever till you find the room and here is a list of all the setting for sensors smoke 26, d/w 13 no delay 10 delay, motion, 20 delay 17 no delay depending, shocks 13 on windows always 13, glass break 14, carbon 26, keyfob 01 there are more but these are most common
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
