Question about Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Panasonic 42 inch television
Panasonic cuts off after a half hour of watching television. The red light blinks the six times. What is my problem?
tv shuts off for no reason and will not come back on right away.My in laws have same exact tv as were bought together.they're tv goes out for almost a day before coming back on.Any suggestions what this could be.
  • 1 more comment
  • tjrklr Jan 01, 2008
    What is a IC that may have blown off?Is this something I can check my self and get parts for also.Is there a way of checking to see if this is what it is?
    Is this a common problem with these sets.
    Thanks for the info sweet rascal,I'de like to accept your answer also.How do i do that?I have one more question.Like i said both my in laws tv and mine are doing the same thing and both were purchased at the same time,it seems like its a problem that panasonic had andthere should be more people with this problem.Thanks tim
  • 579 Answers
Here is a great link to a powerpoint presentation on diagnosing Panasonic Plasma TVs:
www.pasctraining.panasonic.com/pass/elearn/files/Plasma/9th_Generation_Plasma_Display_TV.pdf
Posted on Jan 01, 2008
  • Greg Collins Jan 01, 2008
    You say there is an I.C. with its top blown off?
    That is good as it really helps diagnosing which borad is the problem.
    Bad news is you should plan on replacing that whole board.
    Guru:
  • 1,894 Answers
The blinking light tells you what is wrong with the circuit. If it blinks 3 times it is the convergence amplifiler. I had this problem and tried to fix it myself and I don't think that I have it connected good enough. I know this is the problem with mine. I will let you know if this fixes that. Let me see what 5 blinking lites mean. I will tell you what each blink means from the repair manual, 1 blink is +140 circuit, 2 blinks is Low DC, 3 blinks is convergence, 4 blinks is HHS, 5 blinks is IC4011, 6 blinks is IC4018. I hope this helps. You can get a repair manual at servicemanuals.com it really help
  • 1 more comment
  • dewan nafees ahmed Jan 01, 2008
    the solution was posted from fixya itself.
    tell me if it works.
    its not a common problem and all.
    6 blinks is IC4018 damage.
    this indicates that that IC has to be replaced.
    if you are having good knowledge in practical electronics you can open the set and chage for yourself.
    else its not advisable. so better call a tachnician and he will fix it for you.
    thanks brother.
    thanks for replying brother.
    problems do come with TV sets. you both have bought at the same time right.
    so there are chance that that batch of TVs produced may have been used defective ICs.
    and one more thing to be noted.
    if you have been satisfied with this solution you need to change the rating of mine to fixya. for that try to change my solution to fixya else if not send mail to fixya about this issue.
    anyways thank you brother.
  • 790 Answers
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
  • 1 more comment
  • Kanth raj
    Kanth raj Jan 01, 2008
    or try removing and re-installing the lamp cover on the back.
    may be the lamp cover
    is not seated properly causing the safety switch to not engage all the
    way, when the lamp cover heats up and expands, it fall away further
    from the switch tripping it, shutting the set down.
    when you remove
    and re-install the lamp cover, after you take the single screw out,
    tilt the cover out and forward from the top about 3/4 of the way out
    and then tilt it back into normal position and put the screw back.
  • Kanth raj
    YA ITS A VERY COMMON PROBLEM!! JUST CHECK THIS LINK HOW MANY PANASONIC USERS HAVE THE PROBLEM
    http://stafford.typepad.com/the_next_ame...
  • Kanth raj
2 Suggested Answers
SOURCE: Panasonic 42 inch television
it is probably a circuit boad problem. Seems like I have the same problem just today.
Posted on Dec 24, 2007
Panasonic tv 42 inches plasma model no TH-42PX80EA one red blink light
One blink code indicates main board issue (ALSO can be a BAD panel)
Here is YouTube Link:
https://www.youtube.com/watch?v=HUxD72qoays
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 | Panasonic Televison & Video
12 times blinking red light panasonic plasma tv 42 inch
Please remove any HDMI cables connected to the TV. Then test a different power source. If the problem persists, then we recommend you locate an authorized service center.
Apr 08, 2014 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic TH50PH10 Turn off Automatically
Hi, if your plasma flashes 10 times it means that there is a problem with the sustain driver. This could be an intermittent problem, such as when the set heats up. It should be returned to the dealer as it is under warranty.
Dec 16, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Nov 20, 2007 | Televison & Video
Open Questions:
See all Panasonic TH-42PD25U/P 42 in. Plasma EDTV Questions
Panasonic TH-42PD25U/P 42 in. Plasma EDTV Logo
1,458 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
