Question about HP LaserJet 6mp Printer
Not enough memory LaserHet 6mp Printer HP
Receiving printed message "not enough memory" to print simple emails, etc on my HP LaserJet 6mp. Can I upgrade and add more memory?
Thank you
donna
dgutman2@gmail.com
  • HP Master
  • 705 Answers
Donna,
Yes you can add more memory to this printer. It slots into the formatter (under left side cover)
Memory upgrades
1 MByte—C3130A
2 MByte—C3131A
4 MByte—C3132A
8 MByte—C3133A
16 MByte—C3146A
Add up to 32 MBytes of memory to the HP LaserJet 5MP/6MP printers, for a total of 35 MBytes..
Posted on Dec 30, 2007
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    How do i clear the memory on hp laserjet 3015
    You clean the memory by deleting all the print jobs awaiting for printing.
    Jul 25, 2014 | HP LaserJet 3015 All-In-One Printer
    WHEN PRINTING HP LaserJet P3005n Printer A MESSAGE TONNER REFILS, BUT TONNER FULL
    Toner cartridge memory counts how many print outs passing through it, once memory sensed yield count crossed, printer will say that "low toner" , after couple of prints it will says to "replace the cartridge". If you refilled this cartridge with out replacing the memory printer will treats its old cartridge only.. Replacing the memory will solves your problem.
    Ideal memory chip...
    Sep 05, 2012 | HP LaserJet P3005n Printer
    My HP laserjet 1300 has something blocking the printing process... it spools/pending for a long time then an error msg comes up. Its like a document is caught somewhere in the spooling process but not...
    The last time I had a problem like this with an HP laserjet the problem turned out to be the need for increased memory in the printer and replacing a faulty memory module. Check your memory modules in that laserjet and make sure you aren't overloading the printers ability to process the information.
    Sep 22, 2011 | HP LaserJet 1300 Printer
    It keeps saying memory low, what should i do
    If you already sent a job to print, wait until is finished. These printers have internal memory, like the pc RAM, and if is not big enough you get this message. You can upgrade this memory to a higher capacity. If you haven't sent anything to print, check the printing queue, sometimes it has paused/stopped printing jobs that use up the internal memory.
    Feb 09, 2011 | HP LaserJet CP1515n Printer
    I have a laserjet printer 6mp and i have tried everything and it won't print. even though it says ready int he control panel. please help
    I finally got my LaserJet 6P to work with Snow Leopard - after about a year of it not working
    Using a generic USB to Parallel Connector
    Thought I had tried this before but apparently not
    Went into the Printer Driver and instead of selecting the already recognized HP 6P Driver, I selected
    Generic PCL Laser Printer
    And then checked off the Duplex Box
    Works likes a charm
    Amazing
    Nov 24, 2010 | HP LaserJet 6mp Printer
    On HP 5MP laserjet Printer, on printing a document, the message says: the printer requires more memory than is avaailable in this printer.what to do then?
    You don't say what kind of a document you are trying to print. Did you try to print something else. Did it print?
    Normally if you try and print a complex spread sheet you may get that warning. You have the option of adding more memory or making your print job less complex. Or printing to another printer.
    Oct 03, 2010 | HP LaserJet 5mp Printer
    My HP 6mp prints the test page but nothing else
    if it prints the self test then printer is good
    check your parallel cable or replace it,also delete the printer from printers menu in te computer and Reinstal Drivers.
    Mar 09, 2010 | HP LaserJet 6p Printer
    HP laserjet 1020 fax incoming fax, machine
    hp laserjet is not a fax.It is only a printer.
    Dec 09, 2009 | HP LaserJet 1020 Printer
    Hp laserhet p2015d driver duplex driver for Pagemaker
    Please download and install the Universal Printing Driver - PS version from the followng site:
    If the printer is connected via USB, select the Traditional Mode, if DHCP network, select Dynamic Mode.
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845555&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-36004-15
    Oct 11, 2008 | HP LaserJet P2015dn Printer
    HP LaserJet 6mp Printer Logo
    610 people viewed this question
    Clive
    Clive
