with usb drives getting plugged and unplugged all the time, the connections inside of them and the connections to the usb port will get worn down.
my suggestion, plug it in, place some pressure on the drive (either pushing down or down) and see if the connection comes back. this has work for me in the past. if you get a connection, maintain the pressure, and copy everything on to the computer.
this may have many causes. first possibility: the stick is dead and needs replacement. second: there may be a problem with the usb-port or -controller. if you connect a different usb device to the same port as the stick, and it's recognised, the usb- port is fine and it surely will be the stick which is broken. if the other device isn't recognised either, it's a usb related problem. in this case you should verify if all settings for usb in the BIOS are enabled, if the usb-controller in device manager has been installed supposedly. if not, reinstall, reboot and try again. if this does not work, you need to replace your computer's system board
I just bought the mybook essetial and when I try and hook it up to my laptop I get a blue screen...
(More)
I just bought the mybook essetial and when I try and hook it up to my laptop I get a blue screen with an error message and the computer locks I have tried removing the program I have looked on site for updates and downloaded but the blue screen pops up everytime I plug it in.
seagate model ST30000U2 external hard drive is flashing blue light. computer does not see it. It was...
(More)
seagate model ST30000U2 external hard drive is flashing blue light. computer does not see it. It was working fine before I moved a week ago. It was never dropped or mishandled. I have tried changing usb ports, cables, cords, etc..it still blinks and computer does not see it. I am running vista. Thanks for any help you can give me.
Beeps then clicks inside the drive, but is not visible anywhere on the computer nor on any other...
(More)
Beeps then clicks inside the drive, but is not visible anywhere on the computer nor on any other computers.
Hi, my 500 GB drive lights up and hums after plugging into the USB port on my PowerBook, but the...
(More)
Hi, my 500 GB drive lights up and hums after plugging into the USB port on my PowerBook, but the light is not flickering, and the drive is not mounting. I've tried using externally powered USB hub with no success. Please help, I have a lot of files I need to recover from this drive.
Jerzy
lost menues screen on sumvision cyclone media player/recorder : cant get the menues screens on this...
(More)
LOST MENUES SCREEN ON SUMVISION CYCLONE MEDIA PLAYER/RECORDER : CANT GET THE MENUES SCREENS ON THIS MEDIA PLAYER NEED TO KNOW IF IT NEEDS FIRMWARE DRIVERS ECT:
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
