Open the bag door and grip the bumpers with a set of pliers. The bumpers cover a set of locking keys which will slide all the way forward and out. The back of the vac will then lift off and the top and bottom will open hinging forward like a **** shell. Observe how the front door hinge clips into the lower body before opening teh unit.
If you do this , tag your wires and observe how the pieces interlock. Open the vac with it laying upside down on a piece of carpet.
It will NOT go back togerther unless it is perfectly reassembled , so don't force it.
Post your problem before opening and I will walk you through the reapir
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you for the info, I had no idea how to open the vacuum. Thanks again for your prompt reply
" - bcostain
my electrolux ultralux 2000 was shutting off after using for 10 min then retarting? I thought maybe...
(More)
my electrolux ultralux 2000 was shutting off after using for 10 min then retarting? I thought maybe that it was over heating due to dust/dirt. I took apart blew the dust out put back together but now it does not turn on? I might have crossed wires? Can anybody help me get it back together correctly
Hello! I have an Electrolux Ultralux 2000, w/power nozzle Model N1150. While using it today, it...
(More)
Hello! I have an Electrolux Ultralux 2000, w/power nozzle Model N1150. While using it today, it apparently "choked" on a dolls hair in my daughters room. I removed the hair and checked for any blockage, and there is none. Now, the brush simply won't turn. I have pushed the reset button (ours is a switch) but still nothing. Any ideas??? Thanks!!
I have an electrolux ultralux 80th anniversary edition that was over heating and shutting down. I...
(More)
I have an electrolux ultralux 80th anniversary edition that was over heating and shutting down. I took apart and blew out the dust now when I put it together it does not come on. I may have reconnected the wires wrong and do not have the manual. Where can Im get a manual?
