Question about Nikon D50 Digital Camera
D50 - image problem
When a photo is taken a red dot appears ner the cente wit a line goinf all the ay down to the bottom. Appears wit all lenses/settings etc. A faulty sensor?
It's the CCD sensor. I had to have mine repaired...unfortunately I still seem to be having the same problem when shooting with high ISO. Guess they didn't completely fix it.
Posted on Jan 14, 2008
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
I have a Nikon D50 black image on bottom of screen what is causing this problesm
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
Jan 21, 2010 | Nikon D50 Digital Camera
I recently purchased a canon powershot sx20 15 and it is slow!
You need to do two things. 1. Take a Q-Tip dampened in rubbing alcohol and clean the battery contacts inside the compartment. Clean the battery and the charger also using the same method. 2. Go into your main menu and restore all factory defaults. You should be all set after these steps are taken. Thank you, Dana
Sep 29, 2009 | Cameras
I have phaser 8400 with 40k page count. I am getting a mark on page about 6 inches from top of page and 1/2 inch from left margin. Sometimes it is a faint blur 1/4 inch wide and 1 inch long. Other times...
Run Remove Ink Smears from the Troubleshooting menu. Try running the jetfix snippet found on Xerox website under downloads. It sounds like you may have a defective printhead telling it to spit out some magenta ink at the wrong time.
Jul 05, 2009 | Xerox Phaser 8400 Laser Printer
Split images
use good antivirus with updates and then transfer ur images and cd write it
half middle pic is due to speed of ur pc and viruses
Jun 18, 2009 | Canon EOS 40D Digital Camera
Hi, i am Lata and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. Images cannot be viewed and when i click there appear some horizontal lines....
hi, i am del and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. images cannot be viewed and when i click there appear some horizontal lines. what could be the problem? Can you help please? Rgds del
Apr 21, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
I cant upload my pics to my computer
How To Transfer images To Your Windows XP/VISTA PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To transfer images from your camera to your Windows XP PC, follow these steps:
  1. Connect your camera to your PC using the USB cable.
  2. Turn your camera on, and then select the 'Computer' option on your camera.
  3. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware. Close the pop-up.
  4. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  5. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
    Note: The drive letter associated with the removable disk may be different depending on your system.
  6. Double click the folder names DCIM in the Removable Disk window.
  7. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached in an existing folder, your camera creates a new folder. The folders are labeled successively: 102SSCAM, 103SSCAM, etc.
  8. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  9. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  10. Select 'My Documents'.
  11. Windows copies the folder into 'My Documents'. Depending on how many photos are int he folder, copying may take a few minutes.
  12. Double click the 101SSCAM folder in My Documents to access and view the pictures taken with your camera.
How To Transfer images to Your Mac PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To Transfer images from your camera to your Mac, follow these steps:
  1. Turn on your Mac, and then connect your camera to your Mac using the USB cable.
  2. Turn your camera on, and then select the Computer option on your camera's screen.
  3. An icon appears on your Mac desktop labeled Untitled.
  4. Shortly after, a pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
  5. After downloading is complete, another pop-up appears containing the pictures taken with your camera.
Dec 31, 2008 | Samsung L200 Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Nikon D50 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Computer Links
Are you a Nikon Camera Expert? Answer questions, earn points and help others
