Network connection drops after sleep
I have two macs G4 and G3 10.4.11 networked together through a router. We use the network for internet and printing which works great. Every now and then we need to transfer files back and forth so we connect to one another and that works well. The problem is if the computers go to sleep the connection is dropped and we have to reconnect. Now I have bought a network drive (Iomega) and it also works well but we are plagued with the same problem, when we wake the macs from sleep the drive icon is there but then goes away in a few seconds and we have to go through a re-mount software to get it back. I would like to use this drive for back ups but can't if it will not be there. I know I can get around this by not letting the macs sleep is there any other way?
  • bill vandaele Dec 30, 2007
    I have a Iomega 250 Gig. Storcenter network hard drive with eithernet and USB2 connections. Serial # is KNAG 0306 PE
    There is no password protection set up for this drive. I have plugged it into different eithernet ports with no change. The drive works fine on either mac as long as I don't let the computers go to sleep. If I let one mac sleep and not the other only the one that sleeps loses it's connection.
    President:
  • 1,944 Answers
Could you please tell me what is your exact Iomega drive model? Thanks.
Posted on Dec 30, 2007
  • Damen Wong
    Damen Wong Dec 30, 2007
    Thanks for the exact info. Unfortunately, the sleep function of the Macs has been known to cause problems with connected peripherals ((includes networking) when it wakes up. I will look more into it.
    President:
  • 2,022 Answers
Did you try with changing the port of iomega or try to see is three you applied any password for iomega access.
let me know.
bye
Im using a 2Wire Gateway DSL connected via ethernet to a Mac G4, I also have a laptop running windows vista and it has strong wi-fi connection, sending packets at optimal levels and speed. BUT Problem
Vista has a well known flaw of not allowing you to easily change access rights after selecting "public network" in the initial network connection screens. The easiest fix is to change the name of your wifi access point, reconnect, and be absolutely certain to select "home network" when the prompt comes up.
The best solution however is to ditch that crummy excuse for an operating system and upgrade to Windows 7 or 8.
Oct 05, 2014 | Computers & Internet
Tip
Multiple Computers on Same Network, Continual Internet Connection Dropout
After adding that second or third computer to your home network are you constantly fighting over who's using the internet connection? When your high schooler logs into his facebook chat, are you getting dropped off of your internet connection?
Or have you added a wifi router and is your whole network not staying connected like it did before you added your wifi?
These are common issues and we answer these questions often at FixYa.
Here is s a tip that will get you past the internet connection being dropped by someone else on your network attempting to log into the internet or help you get that wifi up and working with out all the cut outs and drop offs.
Follow this simple procedure and you'll be amazed!
1. Turn off everything. Turn off computers, routers, modem, printers... everything that's on your LAN (local area network) or home ethernet.
2. Turn on your wireless router next. With the ethernet cable connected to your wifi router to your modem and let it cycle up to running. If you aren't running wifi, do this with your main router. Make sure your modem and everything else is still off.
3. Turn on your modem (enet cable attached to wifi router or main router) and let the modem cycle up to running.
What you've done is allowed your wifi router to be established as the "MAC" Address for your modem. Modems look for a single MAC address. Once the router has this address, the router will maintain the connection with the modem and the internet, AND will assign MAC addresses to your computers, network printers, network routers etc, while still maintaining your connection to the internet.
4. Turn on all other peripherals, computers and network printers. At this point the order of power up isn't important, because your router will be assigning separate addresses to all the computers, etc on your network.
That's it! The secret's out! Just keep this handy... remember if you have power outage, you'll need to reboot in this order again... Happy Home Networking
on Dec 02, 2009 | Computers & Internet
Connecting g4 to wpa2 network; option is only wpa
Hi Tom,
Bad news, the old G4 Laptop does not support that protocol...
You can either change the Wireless security int eh router to simple WEP or purchase a wireless PC Card that supports WPA2
but then again.. investing in an old G4 Laptop???
Can you simply run a cable ?
Feb 18, 2013 | Apple Power Mac G4 Desktop
Mac ibook g4 connect to an existing wireless network?
Usual problems are making sure that you select the correct security options at both ends and then DHCP problems. I would disable DHCP on the mac and select your own IP address above the existing ones to start with
Oct 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
Must restart computer to open the internet again
Seems like you need to configure the Power Saving settings so your Network card does not go to sleep. Alternatively, set the hard disk to "Never Sleep", so your drivers don't go offline.
Apr 11, 2009 | Apple iMac G4 Desktop
I just bought a used powerbook g4 laptop. It worked great and I used it at work to connect wirelessly to the internet. I brought it home and cannot get it to connect to my wireless network. I have a belkin...
You could try changing the security. Some of the older laptops have trouble with the new WPA2 security. Use WEP and you should be OK if this is the problem. Good luck TT
Dec 13, 2008 | Apple PowerBook G4 Mac Notebook
Internet connection
The only way to replace the network card is to replace the logic board in this unit, however if you are running 10.5, you can purchase an external USB to ethernet adapter at a local Apple retailer and you can hook the computer to the network through that adapter
Sep 26, 2008 | Apple iMac G4 Desktop
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
N1 Drops when Mac log onto network
OMG I have the exact same problem. I'll be using the router for a week on wifi just fine, then one time when my mac laptop comes out of sleep and tries to connect, the router drops its Wifi network (making it unjoinable for any device, not just my laptop) and I ultimately have to hard-restart it. SO frustrating, this is on v1 btw.
HELP
Feb 20, 2008 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
