Need code #
Hi I need to program my direct tv remot control but I need the code number for the tv.
  • Anonymous Jan 09, 2008
    I need codes to program a 3-in-1 Nexxtech Universal remote Control
Please help anyone have a code for a "sky Italy" satellite ? Thanks
Posted on Dec 30, 2007
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
Need code for a rca coder for a ge tv
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To get the code please go to below website
http://www.rcaaccessories.com/remotefinder/
Please
Provide model of your remote
device to be programmed (VCR,TV)
Thanx
Jul 30, 2010 | RCA RCU300WBL Remote Control
I have a universal remote and need a code to program it to a tv
in the battery compartment, usually on the cover is a 800 number to call for codes
Mar 06, 2010 | General Electric Universal Remote Control
Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
May 09, 2009 | Element ELC-HS321 32 in. LCD TV
I have a new RCR312W TV remote. I have lost directions
Someone had posted a solution to manually program the remote. The information came from RCA website. It worked fine. I still would like the code numbers for my remote. I have a LG TV that is about a year old.
Feb 14, 2009 | RCA Universal Remote Control
NEED CODE FOR TV
Tell me tv and universal remote model first
Aug 14, 2008 | RCA D770 Remote Control
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
Top Televison & Video Experts
