Question about Canon Rebel XT / EOS 350D Digital Camera
Camera functions are locked up
My camera takes one picture, but when I try to take another, it is locked, I have to swtich off and on again.
Additionally, the menu button and picture review button does not work all of the time. Sometimes it works, but more frequently I can't access it.
I tried reloading the firmware and cleaning. Any ideas?
  • ARGODD Dec 30, 2007
    I tried removing the battery, but this did not work.
    I think that you are correct that it is stuck in some sort of post shooting view. I noticed that if you wait long enough (a minute or so) it unlocks and you can take a picture again.
  • 90 Answers
Looks like the camera doesn't go out of the post shooting preview. That could be a software problem. Try removing the camera's battery for 3 minutes to clear the memory.
Posted on Dec 30, 2007
When i turn my camera on it says memory card is protected and i wont take any pictures, what should i do?
The memory card is most likely an SD type and the lock swich was activated I'm including a diagram to show you the correct orientation of this switch, it must be in the open or unlocked position to function. When you have the memory card unlocked Please format the card so the camera can function properly with it. Formatting the card will insure correct programming between the card and the camera. Format the card after downloading pictures to the camera. it both cleans and restores programing so the card and camera are compatible once again.
Lock is down open is up towards the top and closest to the gold contacts
Jan 06, 2011 | Cameras
HI i have a canon ixus 700 it still take great pictures but when i try to use the flach on the camera it wil not take a picture please can you help
It's possible the camera is in one of the manual modes with the flash turned off. With the camera turned on and in the picture taking mode press the function button and look at the bottom of the screen. press the right or left side of the ring to highlite the auto setting then press the function button again.
Dec 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
Jul 14, 2010 | Canon EOS Rebel XSi Digital Camera
When i take a picture it works fine..but then i try and take another picture and it appears the whole functions of the camera is locked up..cant do anything..however the screen still shows a image.. to...
Firstable go on to your camera settings try looking around for the problem if this does not work get it repaired hope you have warrenty if you don't itll be a little expensive so goodluck:) and please rate this solution...
But if this does not work send me an email i will try to think of some more solutions... CYA!
Jun 06, 2010 | Cameras
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Mar 03, 2009 | Canon PowerShot A540 Digital Camera
Protect mode on vivitar vivicam 5386
hi there
this is the disc that you use in your camera correct, put the disc back into camera if so go to your camera setting like if you were going to review your pics.and go to the place where you went to lock the pictures press menu find protect again hit function settings hit select it will bring that picture back up again click function again and this will unlock it. this works for my cannon but it goes something like that hope this works for you its hard to explain but i had the camera in hand its easier do it. i just did it with my sons hope i didnt confuse u
Jan 19, 2009 | Vivitar ViviCam 5386 Digital Camera
My nikon d80 will take a picture in M mode only
there are 2 swtiches of the AF on the D80. 1st is on the lens itself and 2nd is on the left side just below the lens release lock. A/M .. set both to A for auto. cheers.
Nov 27, 2008 | Nikon D80 Digital Camera with 18-135mm...
Optio 60 Card Locked
if it says card locked. take out your memmry card on the side of it should be a white little strip you probably swtiched it to locked! you can unlock it by clicking it up!!!
Jun 23, 2007 | Pentax Optio 60 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
